10-26-2015, 02:16 AM | #1 |
Engine stand
Hi
I got myself an engine stand like the photo. Is there any enigine block issue using this on a 1935 21 bolt flathead. Im planning to bolt it on the gearbox end. Maybe the timing cover end. Most of the flathead stands ive seen supports the engine block in both ends?. Thanks.. Last edited by TDS; 10-26-2015 at 02:21 AM. |
10-26-2015, 03:52 AM | #2 |
Re: Engine stand
TDS, I suggest that you study up on this past Post on Flathead Engine Stands. There is lots of good information in this Post.
https://www.fordbarn.com/forum/showthread.php?t=137608 |
10-26-2015, 08:21 AM | #3 |
Re: Engine stand
I have read many posts here and on other Forums cautioning folks about bolting their flathead engines to an engine stand using the integral cast bell housing. An attachment that will allow bolting the engine at the exhaust ports is claimed to be better.
A stand that bolts to the front and rear of engine could prevent removal of some components during a rebuild.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-26-2015 at 08:29 AM. |
10-26-2015, 08:37 AM | #4 |
Re: Engine stand
I've seen broken bell housings where they've been bolted on that style stand using the bell.
Use the exhaust mounting type, it won't fail. Martin. |
10-26-2015, 08:40 AM | #5 |
Re: Engine stand
GO HERE!!!
http://stumpysfabworks.weebly.com/st..._Products.html http://www.garagejournal.com/forum/s...ad.php?t=84366 http://www.jalopyjournal.com/forum/t...stands.295059/ SCROLL DOWN https://www.fordbarn.com/forum/showthread.php?t=29482 Last edited by Capn John; 10-26-2015 at 08:53 AM. |
10-26-2015, 08:47 AM | #6 |
Re: Engine stand
10-26-2015, 09:12 AM | #7 |
Re: Engine stand
WOWIE!
THAT photo should remove all doubts. |
10-26-2015, 09:37 AM | #8 |
Re: Engine stand
You would think! This one should convince even the "experts". DD
10-26-2015, 09:50 AM | #9 |
Re: Engine stand
A friend of mine, Geoff, had this happen to him as well. Against my advice,he used this type of stand and well, an otherwise good '40 block went to the trash heap.
10-26-2015, 10:16 AM | #10 |
Re: Engine stand
It is very easy to make (or have made) and exhaust mount. You can use a tube that matches your existing stand or make a flat plate adapter. The angle is 45 deg, an exhaust gasket or manifold will give you the bolt pattern.
10-26-2015, 10:39 AM | #11 |
Re: Engine stand
I think I'm going to be SICK after seeing that! And my guess - was using a wrench or breaker-bar to turn it over from the front of the crank. Nice way to apply even more pressure to that thinly cast bell in the back!
AND - that engine had a LOT of expensive stuff in it . . . and was probably ported/relieved as well. Yikes! D |
10-26-2015, 02:06 PM | #12 |
Re: Engine stand
Hi
Okay Im glad I asked - not an good idea. Will make an adaptor. Thanks |
10-26-2015, 03:16 PM | #13 | |
Re: Engine stand
10-26-2015, 04:13 PM | #14 |
Re: Engine stand
V8coopman--need to drill a hole for the stop otherwise you will not be able to position the block
10-27-2015, 02:49 AM | #15 | |
Re: Engine stand
Dale, That there engine was indeed a "high end build" Navarro high dome head/piston combination, Big valves, Big crank, extensive port work, you get the idea. Absolutely no wrenching turning it over with it on that stand. He bolted it on the stand, went indoors for something, came back out, engine on the floor with the bolt holes in the bell pulled out and still bolted to the stand. Damn thing had only been hung on the stand for a short time. As I said, no wrenching on it whilst hung, except pulling the pan.' Martin |
10-27-2015, 07:04 AM | #16 | |
Re: Engine stand
I will sometimes hang a bare block on the other type stand - especially during porting operations as I need to be able to turn it all those funny angles. Once I start to put it together (when all the weight gets added), then I only use the side-mount adapters. Also, the side-mount adapters make it really easy to setup the flywheel, clutch and even test the transmission fitment. I just flip it up and make sure all that crap works as planned. |
10-27-2015, 02:00 PM | #17 |
Re: Engine stand
I can see there is only 4 bolt holes in the adapter - thats 2 exhaust ports.
I going to have one made - any reson to aim for all 6 boltholes to get more strengh? |
10-27-2015, 02:26 PM | #18 | |
Re: Engine stand
10-27-2015, 02:36 PM | #19 |
Re: Engine stand
Does anybody know the radiator cap psi on a 1936 Ford sedan flathead v8
Sent from my XT1080 using Tapatalk |
10-27-2015, 03:43 PM | #20 |
Re: Engine stand
Think this may have gotten posted in the wrong thread? And the answer is zero.
