03-11-2014, 07:04 PM | #1 |
Carb problem??
Pulled my coupe out to today for a quick ride around the block and noticed that when I mashed the pedal, the motor ran real rough and lost power. This was only at a higher rpm at first. I pushed in the clutch and pumped the pedal slowly to get the rpm up again and that made it worse.
I pulled over to the side of the road and after it seemed to clear itself out, it idled perfect. I tried pumping the pedal again and again it ran rough, bogged down and smoked. it was running very rich as I could smell the fuel in the exhaust. I shut it down and pulled the distributor cap to take a look. I have a rebuilt crab. I pulled the rotor off to take a look at the contact and I noticed there was about 1/4" play. I put the rotor back on the shaft and when I turned it clockwise to counter clockwise, back & forth it had all that play. Is that supposed to be like that? Could that be the problem of it running so rich because it's not firing properly? Any help is always appreciated!! Thank you, Joe |
03-11-2014, 08:32 PM | #2 |
Re: Carb problem??
Sounds like a bad Power Valve in the carb. I just lived through a similar experience with both our '39 CS & '39 LZ. The corn gas kills the PV in short order... Contact Charlie NY (he post on the forum), he can set you up with good PV's.
Imagination is more important than knowledge. |
03-11-2014, 09:28 PM | #3 |
Re: Carb problem??
Could be the fuel. I had the same problem after one of my vehicles sat for a while. It sputtered, stumbled and there was smoke coming from the tail pipe. After nursing it home, i put Marvel Mystery oil in the fuel tank and since then it runs like a top. I also had used Stabil the last time I had added gas. Good luck
03-12-2014, 07:22 AM | #4 | |
Re: Carb problem??
Thanks |
03-12-2014, 07:24 AM | #5 | |
Re: Carb problem??
I love that stuff and put a quart in everytime I fill up!! Thanks |
03-12-2014, 08:07 AM | #6 |
Re: Carb problem??
The freeplay in the distr is the mechanical advance, they are springloaded and at rest they'd be in the fully retracted position and as rpm increases the counterweights advance the ignition timing. So, yes, that is normal. |
03-12-2014, 08:27 AM | #7 |
Re: Carb problem??
03-12-2014, 08:41 AM | #8 |
Re: Carb problem??
As stated possibly from all the excess MMO.
03-12-2014, 09:55 AM | #9 |
Re: Carb problem??
Could be lean, but without it in front of me, it's a guess, and it could be anything. Don't assume rich if the exhaust smells gassy, lean will also have unburnt gas in the pipes, overly lean is hard to fire properly.
Again don't assume stuff, lots of carb problems are actually ignition, and vice versa. The play in your ignition if it's just rotational play, I wouldn't be concerned, it's not that unusual, and wouldn't give the symptoms you describe. Martin. |
03-12-2014, 05:07 PM | #10 |
Re: Carb problem??
I agree with Joe and 51 Merc... waaaayyyy to much MMO, It ain't no diesel!.....Matt in Alameda
03-13-2014, 04:38 AM | #11 |
Re: Carb problem??
Wow! I could swear I read here on the Barn that people were putting a quart in their tank!
I definitely will stop that and go with the recommended amount. I sent the distributor & the carb back to the builder just to make sure everything is ok there. Will keep you posted on results. Thanks for everyone's input! |
