Old 08-05-2019, 04:48 PM   #1
Cave
Cave's Avatar
Default Toe-in tools - easy and accurate
Toe-in tools… I rebuilt all steering components from the steering box to the wheel bearings and decided to re-set the toe-in since everything was rebuilt or new and the old slack was eliminated.
Rather than trust my not-perfectly true wheels and tire tread I decided to make these simple and cheap tools out of 1” square aluminum.
Simply bolt one to each hub, rotate them to the rear, measure, then rotate the hub so they face forward and measure again. No wobble, no guessing. I finally have the toe-in correct… 1/16” (actually 3/32” - the tools are that accurate) … YMMV.
Purists with absolutely true wheels may snicker, but in my real world I trust these and found them easy to use… a one-man job.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Old 08-05-2019, 05:08 PM   #2
wmws
Default Re: Toe-in tools - easy and accurate
That looks interesting. How sturdy are the arms and are they contoured to the hub and brake drum.
wmws is offline   Reply With Quote
Old 08-05-2019, 05:13 PM   #3
Cave
Cave's Avatar
The fit is really good... notice the way it sits on the rim in picture #2... they were only finger tight, no wrenching needed.
Cave Luther
Syracuse, NY
Old 08-05-2019, 06:09 PM   #4
biggieou
I'll take one! Let me know how much!
Sent from my SM-N920V using Tapatalk
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 08-05-2019, 06:24 PM   #5
Cave
Cave's Avatar
Square tubing... Lowe's, Home Depot, Amazon, etc.
Hack saw... see above
1/2" drill bit (for lug bolt hole)... ditto
And half an hour of your puttering time. Easy, peasy. (Peasy is a word?)
Cave Luther
Syracuse, NY
Old 08-05-2019, 06:40 PM   #6
biggieou
Yes sir it is! Good stuff. I appreciate seeing people come up with new ways to fix a 90 year old problem!
1950 Mercury 8
Old 08-05-2019, 06:40 PM   #7
Fred K-OR
Fred K-OR's Avatar
This guy not being an expert in this area, this idea looks good to me.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-05-2019, 07:05 PM   #8
whirnot
whirnot's Avatar
Great idea, but as I recall the 1/16 is based on the distance between the tires, and taken from 6 " above the floor. So if your tube is approximately the same length as the distance from stud to tire centerline, and the car is jacked up just the same height as the tire. Then taking this measurement 6 inches above the floor should put you dead nuts.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-05-2019, 09:11 PM   #9
Pilotdave
Pilotdave's Avatar
Cave - thanks for the idea!
Pilotdave is offline   Reply With Quote
Old 08-05-2019, 09:15 PM   #10
walkerlakeprinter
walkerlakeprinter's Avatar
This is awesome! I just ordered a piece of 1" square aluminum tubing from Ebay. I can see this will be really easy to make. Thank you!
walkerlakeprinter is offline   Reply With Quote
Old 08-05-2019, 09:56 PM   #11
daveymc29
daveymc29's Avatar
Why not make four while you are at it and aim them to 6" off the ground, measure and adjust and job done? (If hubs are straight) Looks easier than my curtain rods and blocks of 2 X 6.
daveymc29 is offline   Reply With Quote
Old 08-05-2019, 10:48 PM   #12
Mike Peters
Mike Peters's Avatar
Should the car be on the ground with wheels on to measure toe in? Some slack in the wheel bearings and king pins could affect your measurement? I don't know for sure. Just asking.
Mike Peters is offline   Reply With Quote
Old 08-05-2019, 11:22 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
Use a duby gauge, place it between the tires roll car forward, adgust, done.
Use cut aluminum, jack up car place on stands, remove and preload from the weight of the car on the wheels, remove wheels, bolt on gauge. Measure. take off the gauge, put on the wheels jack it up, remove the stands lower the car hope there was no play in the front end or the wheel bearings, done.
Cheaper, yea. Easier, accurate?
Old 08-06-2019, 10:32 AM   #14
Cave
Cave's Avatar
For clarification… or in defense… my setup is definitely “shade tree”, no expensive tools, no garage floor, just a reliable way to check toe-in in spite of not-perfect rims or squiggly tread. And I won’t argue anyone’s technique – that’s not what the post is about... it's about a cheap and handy tool.
My guide was Les Andrews’ directions on page 2-19:
· jack the front end off the ground
· mark across the tire (tread) with chalk
· bring marks forward in a horizontal line with the hub cap
· measure then rotate tire so chalk marks are behind hub cap
· adjust tie rod as needed
Good enough for country roads. :-)
Cave Luther
Syracuse, NY
Old 08-07-2019, 06:22 AM   #15
Chuck Kuntz
My method is to put a common pin in each tire, measure at 6 inches above the floor in the back, role car forward until pins are 6 inches above floor in the front and measure again. Diffence is toe in or toe out. Cost less than 1 cent.
Chuck
Chuck Kuntz is offline   Reply With Quote
Old 08-07-2019, 07:01 AM   #16
Dave in MN
Dave in MN's Avatar
Clever idea!
FWIW: Using a Duby stick I once adjusted toe in on my Phaeton off the floor on the car lift. Sure was easy. It tracked like crap. I did the same procedure but this time on the floor and it needed re-adjustment. After adjustment, with the load of the car on the components, it went down the road like an arrow. On my car it made a difference.
Every car is in a different state of wear or repair so I am not surprised it will work for some and not for others. In the end, the car needs to go down the road straight and conserve the tires. Use what works on your car.
Good Day!
For info search: Duby Wheel Aligning Gauge
Dave in MN is offline   Reply With Quote
Old 08-07-2019, 08:50 AM   #17
Aretino
Aretino's Avatar
Great post from Cave!
Aretino is offline   Reply With Quote
Old 08-07-2019, 09:42 AM   #18
Cave
Cave's Avatar
Aretino, thank you. Any post will generate input from members with different perspectives. I have to say – the FORD BARN seems to be populated with a dedicated and respectful following. All of us seem to share our comments for the collective good.
Sure, there are negative comments and favorable ones like yours. We grow from contrary points of view and remain encouraged to provide additional threads with compliments like yours.
Read my Red Green quote below…
Cave Luther
Syracuse, NY
Old 08-07-2019, 07:23 PM   #19
sphanna
sphanna's Avatar
deleted
Steve Hanna, Polk City, IA
Last edited by sphanna; 08-07-2019 at 07:36 PM. Reason: I thought it may look like a hijack of Cave's post. so I deleted it. Thanks for the post Cave
sphanna is offline   Reply With Quote
