01-19-2023, 09:52 PM | #1 |
top vinyl question
hi was wondering how the is the visor to the roof is seald of. Does the top bead run all the way to gutter? and if so how is it held there?
01-20-2023, 01:36 PM | #2 |
Re: top vinyl question
anyone have an answer
01-20-2023, 02:00 PM | #3 |
The front top molding that secures the top material on the front header, was installed from the drip rail on one side all the way across to the drip rail on the other side. This molding was nailed on. It was likely an extruded aluminum molding that came with the two lips open and then the lips are closed down over the nails after installation. Some two piece steel moldings were used on model A cars but I'm not sure about the Coupe. These have an inner strip that nails down the top material to the header and then the outer piece is snapped over the inner one to cover the nails. The 45B coupes should have the style #1 that is 5/8" wide flat bottom extruded aluminum molding with the closeable lips. A person can use certain sealant being conservative with their application around the edges but I would avoid those that can have an adverse affect on bare steel like some RTV sealants that have acetic acid in there mix. If everything is primed & painted then it shouldn't affect things too much. Last edited by rotorwrench; 01-20-2023 at 03:23 PM. |
