11-08-2011, 07:30 AM | #1 |
Fuel Pump
I'd like to rebuild the fuel pump on my '47. The kit's only $20 & it's a simple job except for one thing: Does anyone know how to remove the 2 valves in the upper housing? This one's really got me scratchin' my head!
I'd appreciate any help with this. |
11-08-2011, 07:41 AM | #2 |
Re: Fuel Pump
This is an after market pump not an "AC" pump. The valves are pressed in and slightly larger than stock original valves.THIS is the type of pumps that CANNOT be rebuilt.I have original "AC" pumps that i rebuild and have replaceable valves so can be done again down the road if needed.Plus i install a paper filter in the bowl. PM or email [email protected]
11-08-2011, 07:42 AM | #3 |
Re: Fuel Pump
HEY GUYS, look at this pump,this type cannot be rebuilt,dont even try it. ken ct.
11-08-2011, 07:48 AM | #4 |
Re: Fuel Pump
Those valves are pressed or staked in place and difficult to remove. Then I'm not sure how the new valves would be held in place. The FP's I rebuilt all had valves held in place by a small sheet metal part and two small screws. The ones I rebuilt are still working well.
I bought kits from MAC's that they claim were originally supplied by Joblot. Apparently the diaphragms were made of material that holds up well to this gas with alcohol.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 11-08-2011 at 07:59 AM. |
11-08-2011, 08:00 AM | #5 |
Re: Fuel Pump
Thanks so much for the replies!
I kind of figured it wasn't rebuildable, so I'll just have to spend the $60 on a new one. |
11-08-2011, 09:00 AM | #6 |
Re: Fuel Pump
Got mine 2 yrs ago, still works great. He does quality. |
11-08-2011, 09:35 AM | #7 |
Re: Fuel Pump
Ken's pumps are excellent and he stands behind his work. Vic
11-08-2011, 09:46 AM | #8 |
Re: Fuel Pump
LH,
Hold on to your $60. Many new pumps are made far far away and have a tendency to produce too much pressure, some as much as 7 psi. I've unwound more than a few carburetor problems that were directly a result of too much pressure from a shiny new pump. I'll ditto what Vic says. Charlie ny Yep I know some new pumps are just fine but I also know lots are not |
