Old 07-18-2019, 06:31 PM   #1
russcc
Default '34 Front radius rod ball caps
Are the ball diameters, top & bottom caps the same for Model A through early V8 or are they different ? Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 07-18-2019, 06:42 PM   #2
DavidG
DavidG's Avatar
Default Re: '34 Front radius rod ball caps
As I recall, at least some the Model A bottom caps were cast steel, whereas the V8 era caps were stampings. Further, no rubber ball bushing was used on Model As, which suggests that the caps were smaller in their inside diameter. There was no top cap used in the V8 era as the recess for the ball and its rubber bushing was stamped into the center cross member.
