Old 01-26-2023, 07:49 PM   #1
B-ster
Default Is rusty t. Stat housing useable?
Here's my thermostat housing. It's got rust inside and around the hose end. On the end the rust isn't soft or holey but rough. I'll be installing a new thermostat of course but not sure if this should be replaced. I also have rust in the intake manifold that you can't get to. Any advice?
B-ster is offline   Reply With Quote
Old 01-26-2023, 09:30 PM   #2
Ole Don
Ole Don's Avatar
Default Re: Is rusty t. Stat housing useable?
I would clean all surfaces with a wire wheel, then re-evaluate the gasket surface. If you have an electric sander, go over that surface with some medium paper to flatten it. On the intake, use a stainless tooth brush, then the sand paper on a flat board. Stay away from silicone.
Ole Don is offline   Reply With Quote
Old 01-27-2023, 02:54 PM   #3
Fortunateson
As said above but you may want to perform Reverse Electrolysis on it (google it) as well. For any pitting you may be concerned about a wee bit of JB Weld would be fine I’m sure.
Fortunateson is offline   Reply With Quote
Old 01-27-2023, 07:48 PM   #4
Hot Rod Reverend
Hot Rod Reverend's Avatar
Consider electrolysis if you do not have a blast cabinet. While it may be overkill for the housing, it may help with the intake manifold or any other parts that need rust removal. I have a blog post about this - https://www.hotrodreverend.com/post/...haust-manifold
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
