10-02-2022, 06:45 PM | #1 |
Distributor
Trying to figure out the material that is in the condenser screw hole is?
Any body know? |
10-02-2022, 08:34 PM | #2 |
Re: Distributor
There is a bakelite washer that prevents the condenser from shorting out and on the outside of that was originally a "plug" made of some kind of resin to keep water out. They sell a rubber plug that does the same thing now.
"The more things change, the more they stay the same." |
10-02-2022, 09:09 PM | #3 |
Re: Distributor
Thank you cris
I undstand the plug it is not exceptble in the fine point trying to find the original material that they used. Thank you again Earl |
10-02-2022, 11:48 PM | #4 |
Re: Distributor
I believe the original plug used by Ford was beeswax. One can get this by purchasing candles made from beeswax. they don't drip wax when burning them I found out too.
I suppose you could pinch off a bit, heat it with your hand or hot water and form a plug with it. |
10-05-2022, 01:48 AM | #5 |
Re: Distributor
Toilet bowl rings typically are made from beeswax and are redly available at your local hardware store too.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-05-2022, 09:15 AM | #6 |
Re: Distributor
10-05-2022, 12:25 PM | #7 |
Re: Distributor
