09-06-2012, 07:30 AM | #1 |
Make Your Own flathead Engine Stand
Here are the pics.
09-06-2012, 10:44 AM | #2 |
Re: Make Your Own flathead Engine Stand
Now that is brilliant! I have Stumpy's but the engine is unbalanced fore and aft on the stand.
Son, you will never blow an engine up in high gear. |
09-06-2012, 12:21 PM | #3 |
Wow, there is a lot of work and engineering there. Can the crank be removed or installed with the setup?
09-06-2012, 02:37 PM | #4 |
The engine stand is made from 2 habor freight stand bought from craigslist. The stand is design from original stand back in the day. Big circle in front lets you put the cam in or out.
09-06-2012, 09:12 PM | #5 |
Again, can you install the crankshaft assembly with the block on your stand?
09-06-2012, 09:31 PM | #6 |
09-06-2012, 10:07 PM | #7 |
Wasn't this on the HAMB?
09-06-2012, 10:21 PM | #8 |
09-07-2012, 06:54 AM | #9 |
09-07-2012, 08:41 AM | #10 |
Kool engine stand but that Columbia two speed next to it is even cooler!
09-07-2012, 10:05 AM | #11 |
One I built. Was being used as a dolly in the picture. Plates bolt to exhaust ports and will spin 360*
I dig coal, which provides motivation for EVs. |
09-07-2012, 11:06 AM | #12 |
09-07-2012, 11:27 AM | #13 |
09-07-2012, 12:45 PM | #14 |
I saw one similiar to mine in an old photograph in a V8 Times magazine.
10-05-2013, 08:13 PM | #15 |
The lower priced HF 4 wheel stand works well as an engine storage dolly with a little rework.
