02-02-2014, 10:36 PM | #1 |
Resistor -fuse bar problem
Has anyone ever had a problem with the resistor-fuse under the dash on a 37 Ford? I have one that reads about 6 volts going in and 2.9 volts coming out to the coil. Any suggestions and help would be greatly appreciated.
Thanks PS - I have ordered another resistor-fuse bar. |
02-02-2014, 10:57 PM | #2 |
Re: Resistor -fuse bar problem
Yes, I have had that problem. Cheap resistor, in my case. When it warmed up, the voltage got lower and the car would stall.
02-02-2014, 11:07 PM | #3 |
Low battery, dirty ignition switch, poor wire connection and some resistors have a bad connection where the nichrome wire is connected at each end of the resistor. A long rivet holds the two ends of the resistor together spaced by the ceramic tube the wire is wound on. The start and stop ends are captured between the ends and the ceramic. I find on some this connection is not very good. I bend the slotted covers up, scrape the ends where the wire comes in contact. Keep the mounting pads in line with each other, push the end layer of the wire against the ends with a scribe and solder using acid flux. regular solder flux won't work you need acid or the solder won't stick. Clean with baking soda and water, blow dry and bend the cover back in place. I would rather use a soldered old resistor than a new replacement. G.M.
www.fordcollector.com |
02-03-2014, 07:11 AM | #4 |
The resister is about .5 ohms and best way to measure voltage is across resister that way what goes in same goes out.
02-03-2014, 08:50 AM | #5 |
If I am not mistaken, the resistor is 0.4ohms. The coil and resistor should be about 1.4ohms. I use a modern wire wound with aluminum fins for cooling resistor. Half the price of the original, should last longer, performs better, but looks modern. A choice, if interested.
P.S. I corrected my error of 1.4 ohms for the resistor alone. Last edited by Joe KCMO; 02-03-2014 at 11:59 AM. |
02-03-2014, 09:10 AM | #6 |
02-03-2014, 09:13 PM | #7 |
ppt
02-04-2014, 08:24 AM | #8 |
I have had to sand the nuts, resister surface, terminals and so on on cars that have been setting for a while.
