12-06-2020, 10:11 PM | #21 |
Re: Bad Stud thread
Thanks for that bit of info.
12-07-2020, 06:12 AM | #22 |
Re: Bad Stud thread
Correction 2 UNC nuts on the bottom of the stud not UNF OOOOOPS !!!
John in same place same weather . |
12-07-2020, 08:10 AM | #23 | |
Re: Bad Stud thread
The way I took it (-when Katy suggested annealing) was "Can this also be done on a graphite gasket?" -as in can this be done on this type gasket also.
I will tell you straight-up that the Model-A deck surface will NOT hold 75 lbs of torque without distorting. If the deck is distorted or the RA finish is not good enough, you will never get a Graphite gasket to seal (-new or used!!). Quote:
12-07-2020, 03:17 PM | #24 | |
Re: Bad Stud thread
12-08-2020, 06:53 AM | #25 |
Re: Bad Stud thread
Here it is in it's current state. I will take a plastic razor blade and trim the blue sealant off after it sets up around the water neck. It just looks better.
12-08-2020, 03:47 PM | #26 |
Re: Bad Stud thread
12-08-2020, 04:20 PM | #27 |
Re: Bad Stud thread
In the bargain rebuilt engine I purchased when I screwed the head bolt into a helio coiled hole the stud was leaning so I marked the side and bent it in the press so it would be vertical.The only problem now is that the head would have to come off to remove the stud.So I remember which one it was I put a dab of nail polish on it,my secret!
