Old 10-02-2011, 03:27 AM   #1
devilswillys
devilswillys's Avatar
Default Convertible top 1936 differences
Hi all
Is there a difference in the shape off the top
I have noticed if it is a rumble seat the top is more sporty than a club cabriolet
Do the top fit on both models if i wish to convert
Thanks everyone
Tim
devilswillys is offline   Reply With Quote
Old 10-02-2011, 06:17 AM   #2
V8ER
Default Re: Convertible top 1936 differences
The top irons for '36 club cabriolet fit nothing else. The top irons for '35-'36 cabriolet fit nothing else, and are quite different from '36 club cabriolet top irons.
V8ER is offline   Reply With Quote
Old 10-02-2011, 08:47 AM   #3
Shadetree
Shadetree's Avatar
I don't believe I have ever seen a 1936 club cabriolet. It has to be super rare. Note the angle of the spare tire carrier to clear the trunk lid.
Thanks for sharing.
Shadetree
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 10-02-2011, 02:28 PM   #4
devilswillys
Thanks for the fast answer
I own the vineyard green Club Cabriolet, and i was thinking of finding a set off top irons for a cabriolet to have more sporty look
My next christmas wish is to have a set of steel wheels with hubcaps and trim rings
I know it is a hotrod sorry, guys
The car was bought original at barrit jackson in 2010 http://www.barrett-jackson.com/appli...&aid=323&pop=0
Bought the car as it is today and i am very happy with this combination
i just want the car to look a little more original
Thanks for your help
Tim
Old 10-02-2011, 02:36 PM   #5
Gary Tosel
Gary Tosel's Avatar
I believe the angle of the spare is because of the carrier from a sedan and not a Coupe, Cabriolet or Roadster. My 5W Coupe has a trunk with the lower angle carrier and does not interfere with the trunk lid.
Thanks
Gary Tosel is online now   Reply With Quote
Old 10-02-2011, 02:43 PM   #6
devilswillys
Great i think the carrier looked a bit odd too
Do you have a pic of your cars carrier, Gary
I have a spare carrier, from a 5w coupe i have sold, i could try and see if it is a different angle
Thanks Tim
Old 10-02-2011, 02:47 PM   #7
DavidG
DavidG's Avatar
The purpose of the longer, more upright top on the club cabriolet is to provide adequate head room for the rear seat passengers. In other words, the design intent was practicality, not aesthetics.
Old 10-02-2011, 04:15 PM   #8
Gary Tosel
Gary Tosel's Avatar
Photo of my 5W Coupe spare tire and carrier.
Thanks
Old 10-02-2011, 04:30 PM   #9
Henryat1140
Henryat1140's Avatar
I am pretty sure the spare tire carrier for the cabriolet and the club cabriolet are different. The Club Cabriolet used a special angle which was to accommodate the trunk opening. The bolt pattern might be the same but the angle is different.
Henryat1140 is offline   Reply With Quote
Old 10-02-2011, 06:36 PM   #10
Mike in AZ
Mike in AZ's Avatar
what DavidG said....a lot more rear top area with club vs. regular cabriolet....irons from regular cabriolet might work, but fabbing a top to fit would be interesting.....Mike
Mike in AZ is offline   Reply With Quote
Old 10-03-2011, 12:34 PM   #11
deuce5wndw
deuce5wndw's Avatar
Trunk lid on the Club Cabriolet is longer than the coupe, roadster, or Cabriolet thus the tilt on the spare tire carrier.
deuce5wndw is offline   Reply With Quote
Old 10-03-2011, 05:40 PM   #12
35cab
35cab's Avatar
Hell of a lot of work to make that swap.
My 35 cabriolet had been modified to accomodate two rear seats, the deck had been shortened, sort of a pre production club cabriolet. I wanted to return it to the regular factory spec so had to piece in extra length between rumble lid and cockpit. Had to remake top irons as mine had been modified. A lot of work, not quite convinced I got it spot on but it had to be done. As it has been mentioned the club cabriolet top is a very different top, built to take two extra heads!
You could perhaps re shape top bows, lower them a bit to give a bit more rake, but to be honest your car is a club cabriolet and it is probably best left the way it is. It is a rare car.
I only did mine because it was a bad conversion in the first place plus there was no such thing as a 35 club cabriolet.
It is your car of course but I would really advise leaving it as is, if you want to personalise it how about rear fender skirts, they take the eye down and away from the top.
35cab is offline   Reply With Quote
Old 10-05-2011, 03:33 PM   #13
devilswillys
Thanks for all your answers
I can see what you mean, it is very different
I think my 2 daughters will be happy if i keep some good space for their heads
thanks again
Tim Kirkegaard, denmark Europe
