03-12-2020, 04:11 PM | #21 |
Re: S/n help
The only plate inside the engine bay is riveted onto the frame by the steering column with the s/n on it. There is a plate on the firewall, but on the right in front of the driver, that's looks like it's been painted over, tired to clean it off but it seemed to have nothing stamped on it.
03-12-2020, 04:24 PM | #22 |
Re: S/n help
Also, I don't know if it matters but I believe it's the "business" super deluxe coupe.
03-12-2020, 04:35 PM | #23 | |
Re: S/n help
Bad information.....Ford had NO ID plates on the firewall before 1949. This picture (thank you to Mac VanPelt) should get you familiar with serial number stamped on transmission bell housing thru 1948. DD |
03-12-2020, 04:40 PM | #24 |
Re: S/n help
My grandpa was never that good to me. He had a '41 Plymouth and I still didn't get it.
Nice lookin' car. |
03-12-2020, 04:42 PM | #25 |
Re: S/n help
V8COOPMAN
Yes, this is what I found as well but I don't have the time or tools untill I get the car back home, to remove the floor board to check the top of the transmission bell. |
03-12-2020, 04:48 PM | #26 |
Re: S/n help
03-12-2020, 05:40 PM | #27 |
Re: S/n help
This is from Vanpelt's site.
From 1932 through 1948 vehicles, Ford Motor Company stamped the serial number into the top of the driver's side frame rail in three locations. This same number was also stamped into the top of the transmission-to-engine housing portion of the transmission. This location was visible when the floorboard and transmission cover plate were removed (click here for a picture example). Of the frame-stamped serial numbers, only the forward-most stamping was visible when looking down into the engine compartment (located between the front crossmember and the dash (firewall). The two other frame locations are visible only when the body is removed from the frame. The serial numbers were metal stamped with numbers/letters approximately 1/4" in height. |
03-12-2020, 05:43 PM | #28 |
Re: S/n help
I think you will find that the 'Business' coupes have the short door (same as the Fordor Sedan and Sedan Delivery), yours appears to have the longer door which might make it a 'Sedan Coupe'?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 03-12-2020 at 05:49 PM. |
03-12-2020, 05:51 PM | #29 |
Re: S/n help
Here's a picture
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
03-12-2020, 05:55 PM | #30 |
Re: S/n help
Another
03-12-2020, 06:11 PM | #31 |
Re: S/n help
VanPelt Sales has a decent listing but it doesn't include commercial pickups.
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm 98R sounds like a 1949 pickup ID number. Where is this number stamped on the car? Ford stamped transmissions and frames but eventually they stopped stamping the transmissions. Someone may have used a 49 pickup title to get it legal. The F1 pickups only had the number stamped on the frame and on a little metal tag that was attached to the glove box door. I wonder if that's where the tag came from. Folks will try all sorts of stuff to get a car legal. That old car likely has the original number stamped on the frame near the steering box. Last edited by rotorwrench; 03-12-2020 at 06:17 PM. |
03-12-2020, 06:26 PM | #32 |
Re: S/n help
when my grand mother was moving to the nursing home in the mid 70's she was still driving the 46 plymouth coupe she bought new. when i asked about the car, my mother said they gave it to the kid at the gas station who kept it running for her. when i started whining about that, she said" THAT OLD THING ?, YOU WANTED THAT OLD THING ? it was like new, and in AZ most of its life, probably still is. any way nice old ford grampa left for ya!
03-12-2020, 08:23 PM | #33 |
Re: S/n help
I have never heard of a plate being attached to the frame with the serial number on it in these years. Something strange is going on here. It could be an assigned number by a DMV, or maybe someone found the original stamping difficult to read and decided to improve it with the addition of a plate, or whatever. I would be willing to bet It did not come from Ford that way. It is possible that if the original numbers were difficult to see that they were misread when the Plate was added. Lots of possibilities here. Perhaps there was a frame change and they were attempting to keep what they believed to be the original serial number for the vehicle.
03-12-2020, 08:39 PM | #34 |
Re: S/n help
Careful. My 46 has a plate on the firewall. The Van Pelt site is normally correct I'm sure but it isn't consistent with the side shift trannys I've seen.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-12-2020, 10:44 PM | #35 | |
Re: S/n help
There is likely a data or patent plate on the firewall, but Ford DID NOT rivet a serial number to the firewalls on '46 Fords. As far as the transmissions BEFORE 1949, they all had the serial numbers hand-stamped on the pad shown when it was attached to a V8 engine. The '32-'53 flathead V8 ENGINES never had serial numbers applied. The engines and transmissions were shipped to assembly plants as a married unit. When the engine/transmission assemblies (with the serial number stamped into the trans) were installed into a vehicle chassis, the number on the trans was hand-stamped into the chassis in three places on automobiles, and in one place on light pick-ups. All the above info is well documented. DD |
03-13-2020, 07:38 AM | #36 |
Re: S/n help
Very nice 46, God bless your Grandpa !
