04-27-2014, 10:52 AM | #1 |
Clutch Release Equalizer Bar
On my 50 Custom there is a bronze bushing in the pivot bolt hole on the clutch release equalizer bar. It looks quite worn. Does anyone make/sell these? Thanks
Gene |
04-27-2014, 01:37 PM | #2 |
Re: Clutch Release Equalizer Bar
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
04-27-2014, 06:42 PM | #3 |
Also check the condition of the ball that bolts to the frame and the hole on the equalizer bar (also known as clutch release lever). The ball might out of round. The equalizer bar hole might be badly worn on one side, too. Good luck.,,jack
Proud FNG We fixem cars. Heap Good! Last edited by jack orchard; 04-27-2014 at 06:54 PM. Reason: because i wanted to |
04-27-2014, 06:59 PM | #4 |
Most of the repo guys have them and you could still get them at one time from your local Ford dealer. I worked for a dealer up until 2 years ago and I ordered them from our facing depot. They fit a lot of different model Fords ( cars and trucks ) up into the mid 70's. If you have a parts book, look them up or maybe someone here has the part number handy and you can call a local dealer and ask.
Barry 50 F-1 |
04-27-2014, 08:04 PM | #5 |
