07-13-2022, 12:08 PM | #1 |
Radiator hoses for 1935 ford
Can anyone recommend a source for radiator hoses for a 1935 Ford. I have tried many of the usual sources an all seem to be out of stock. Any help would be appreciated.
Thanks in advance. |
07-13-2022, 01:27 PM | #2 |
Re: Radiator hoses for 1935 ford
Do you have a stock engine? Someone is making a hose for the 35-36 with a later engine with the hose connection in the center of the head.
07-13-2022, 01:49 PM | #3 |
Jack, Napa sells straight radiator hose by the foot. Just figure out the inside diameter(s) and total length you require.
07-13-2022, 05:53 PM | #4 |
I purchased a set of red line hoses for my ‘36 Phaeton from Joes - good fit, although lower hoses elicited the usual profanity trying to bend the unbendable into a too small space. Note that upper hoses went in without modification while both lower hoses required trimming prior to application of profanity.
No job’s done ‘til it’s all done |
07-13-2022, 06:59 PM | #5 | |
Jacques, Next time that job comes up, simply disconnect the front motor mounts and lift the engine sufficiently to angle a hose onto the inlet/outlet. Then as you lower the engine, that hose knows where it's going. Do one hose at a time, orient the clamps to convenient positions, and while you're at it, replace your mushy old motor mounts.
Alan |
07-13-2022, 07:43 PM | #6 | |
Nahh! That's way TOO easy! Coop . |
07-13-2022, 07:46 PM | #7 |
These are the only sets we have in at the moment
#05729 RADIATOR HOSE SET- FORD SCRIPT - RED STRIPE 1932-36 4 HOSES - 8 CLAMPS FOR STOCK FLATHEAD ENGINE LIMITED STOCK https://www.vintageford.com/part_sea...5729&Category= |
07-13-2022, 11:53 PM | #8 |
I like to use " sil glyde" on hose installations, slides on easy and comes off without a fight years later. Napa brand name, I suppose there are others similar
07-13-2022, 11:58 PM | #9 |
From that name, it sounds like silicone, and there isn’t anything better for rubber.
Alan |
