Old 01-05-2018, 07:42 PM   #1
Steve in Tampa
Default Model a frame
Have a 1929 frame someone changed the front cross member to 30-31. I would like to go with 30-31.Will all components line up for 30-31, running boards, fender brackets , etc tall rad? steve
Steve in Tampa is offline   Reply With Quote
Old 01-05-2018, 08:34 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: Model a frame
You may have to drill a couple of bolt holes, but I think everything should line up.
glenn in camino is offline   Reply With Quote
Old 01-05-2018, 10:24 PM   #3
Steve in Tampa
are the bolt holes for the body
Old 01-06-2018, 04:45 PM   #4
Sunnybrook Farm
Sunnybrook Farm's Avatar
I think that I read somewhere that the late 29s had the new style cross member and that the factory added washers until the new radiators came out. If so then you may have the original cross member unless you can tell it was messed with.
Sunnybrook Farm is offline   Reply With Quote
Old 01-06-2018, 06:45 PM   #5
GPierce
GPierce's Avatar
On Steve's site is everything you need to know about the frame and it's evolution.
http://www.plucks329s.org/frame.htm
GPierce is offline   Reply With Quote
Old 01-06-2018, 08:02 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
My September 29 has the late style front cross member . It looks like it came that way .
