04-26-2019, 05:47 AM | #1 |
1937 ford chassis-vs 1940
will a 40 coupe body fit on a 37 chassis wo any mods?
thanks! |
04-26-2019, 06:00 AM | #2 |
Re: 1937 ford chassis-vs 1940
yes, 1935 to,40 and 1941 pick up , will work ,
04-26-2019, 06:08 AM | #3 |
You will have to fit the 40 brake pedals, the hole is different. The radiator mounting brackets will need changed to the 40 style.
If it's a 37 v860 chassis a couple other things need changed. In general, it will fit |
04-26-2019, 06:30 AM | #4 |
MEMBER EMERITUS
Front cross member and the centre box section will need to be changed out as well.
04-26-2019, 06:36 AM | #5 |
man you guys are good!
only posted this about an hour ago. yes it is the 60hp............. |
04-26-2019, 08:35 AM | #6 |
04-26-2019, 01:19 PM | #7 |
Your DMV may want to register your car as a 1937 based on the serial number when you change the frame. Whatever you do be sure to keep them happy.
Charlie Stephens |
04-26-2019, 03:02 PM | #8 |
no problem in NJ- all good. we have no inspection on antiques. |
