Old 09-03-2017, 10:59 AM   #1
jhowes
Default electrylitic derusting again.
I have used this method several times but recently read that a low voltage, say 6 volts or less works just as good as a higher voltage. I have a setup where I have 2 12 volt batteries in series so the system works off of 24 volts. Am I wasting my time with the extra voltage, or, what is the experience of others? Jack
jhowes is offline   Reply With Quote
Old 09-03-2017, 01:17 PM   #2
aermotor
Default Re: electrylitic derusting again.
Don't need all that, I use a 6 volt battery charger and it works at 2 amps. When the amps drop clean the plates or whatever you use (I use old lawnmower blades) and you are back in business. Electrolysis is pretty much "line of sight" so you may have to rotate your part in the tank.
John
aermotor is offline   Reply With Quote
Old 09-03-2017, 05:26 PM   #3
Kevin in NJ
Vince Falter has some good details on E rust removal.
I took his advice and bought the carbon electrode and that is a great suggestion.
Kevin in NJ is offline   Reply With Quote
Old 09-03-2017, 09:49 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
John
X2, except I used rebar. Next time I'll try Vince's way by using carbon.
Old 09-03-2017, 10:11 PM   #5
Jim Mason
Jim Mason's Avatar
Amps per square inch important, volts not so much
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
