Old 08-28-2017, 09:32 PM   #1
wingski
wingski's Avatar
Default missing V.I.N.
Well, the missing V.I.N. number is solved on my ’29 cabriolet. I took it to the Oregon State Police vehicle inspector today, and he couldn’t find a frame number either. So, now the new number is a simple 5 digit number that even I can remember. I also discovered the neatest job in the world. Curt has been with the state police for 30 years and for the last 20 he’s been inspecting cars for V.I.N. numbers. He said the only thing he regrets is not taking pictures of some of the awesome cars he’s seen and touched.
wingski is offline   Reply With Quote
Old 08-28-2017, 10:59 PM   #2
1955cj5
1955cj5's Avatar
Default Re: missing V.I.N.
Very good.....I also have an assigned number, but luckily it just happens to be the stamped frame number.....They had to issue a new title as the one that came with the truck (in 1962!)had a different number.
Good for you that's one crisis resolved!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-29-2017, 09:40 AM   #3
wingski
wingski's Avatar
While I was talking to the inspector, I said that I was thinking about using an engraving tool to put the new number permanently on the frame. He agreed that was an excellent idea, but told me to put it somewhere that only my wife and I knew about. I’m thinking that I’ll put by the left rear shock or on one of the frame horns. I’m so glad that all this is over because I didn’t really feel that we owned that car until we had our names on it’s title.
Old 08-29-2017, 09:51 AM   #4
SeaSlugs
SeaSlugs's Avatar
put it in several places - put it somewhere one can read it like backside of a crossmember or inside a frame rail then put it in another place that you cannot get to or be seen with the naked eye. That way IF it gets stolen and someone "scrubs numbers" they think they got it - the obvious one. The hidden one you can say "if you lift the body and its right there" and it is with your number well closed case.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-29-2017, 09:51 AM   #5
Big hammer
I wonder why the officer said place it where only you or wife knows it location?
On modern cars it's where everyone can see it, lower driver side dash seen through the windshield! Anyway do as they say, and keep all paper work!!!!
get a bigger hammer tap done
Old 08-29-2017, 11:02 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
There's also a hidden number that most of us don't know where it's located, but the police can find it. I just recently learned that even my 1950 Studebaker has a number on the rear frame crossmember.
Old 08-29-2017, 11:32 AM   #7
BillCNC
BillCNC's Avatar
Does that new number drop the value of the car simply because the assigned Vin?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 08-29-2017, 12:10 PM   #8
SeaSlugs
SeaSlugs's Avatar
Regards
Bill
I dont see why it would. Sure a legible frame number and matching engine number is worth more but my guess this is already mismatched and too rusty to see number anyways. If anything it might be easier to sell as its already cleared with the state.
Old 08-29-2017, 02:14 PM   #9
msbrown6
msbrown6's Avatar
I had a great deputy in Idaho do a VIN inspection on my '29 Phaeton when I first purchased it - and, no surprise, no body # to be found. I suspect it is hiding on a frame member - and under the body. I understand that not all As had frame numbers assigned. Thankfully, he was very understanding - and I got the vehicle titled. Idaho has a process where they will tag the car with the historical VIN number - but I elected not to do that as it is not authentic appearing.
msbrown6 is offline   Reply With Quote
Old 08-29-2017, 02:33 PM   #10
Chris Haynes
Chris Haynes's Avatar
I guess they were too lazy to lift the body to look for the number on my Tudor. So instead it is registered by the engine number. Which happens to be a grind off/re-stamp. I letter and 3 numbers. So I am going to lift the body in search of the real number. Then take it to DMV and CHP and have my car registered by the number it should be registered by. I will also use the reproduction stamp set to put the number in a couple other, more obvious, places.
1921 Runabout
1930 Tudor
Early 1930 AA
