08-10-2018, 08:34 PM | #1 |
Loose fuel pump eccentric
Did a search and I couldnt find any answers, so Ill have to ask here on the board.
I changed the timing chain on my 59 292. I installed the gear, fuel pump eccentric, spacer, washer and cam gear screw. And the fuel pump eccentric is still loose. There is a .045 gap with screw bottomed out on the cam. What am I not seeing? Are there different cam gears from early to late style yblocks? There wasnt a counterweight installed on old timing set.....Thx |
08-10-2018, 09:36 PM | #2 |
Re: Loose fuel pump eccentric
This should help.
Oldmics |
08-10-2018, 09:44 PM | #3 |
Or for a 57 and later engine
Oldmics |
08-10-2018, 10:03 PM | #4 |
Thanks for those pictures!
08-10-2018, 10:14 PM | #5 |
Hopefully that rear thrust washer is stuck on the backside of my timing gear. The 59 Ford Shop Manual doesnt show a nice assembly pic like the one you showed....
08-11-2018, 06:14 AM | #6 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
08-13-2018, 05:20 AM | #7 |
Oldmics ...??? What year(s) SHOP MANUAL(S) did you source those Illustrations from? Did you find the problem?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
08-13-2018, 06:27 AM | #8 |
x2 |
08-13-2018, 01:24 PM | #9 |
Oldmics ...???
What year(s) SHOP MANUAL(S) did you source those Illustrations from? The answer is |
08-13-2018, 03:20 PM | #10 |
thanx!
