04-14-2011, 12:50 PM | #21 |
Re: '39 pedals with 8BA bellhousing?
I used 39 pedals in my 36 w/ a T-5 conversion and 8BA. I used the truck bellhousing and a 39 type clutch lever. Worked out great. I tried using the 40 ford style ball pivot set up w/ the 8BA tab style clutch rod since I already had the pedals and couldnt find a good 39 lever, but I had a tough time getting the geometry right on it and the clutch was very hard to engage.
I have some pics in my build thread below: https://www.fordbarn.com/forum/showthread.php?t=32731 Last edited by DirtyDan; 04-14-2011 at 02:32 PM. |
04-15-2011, 02:05 PM | #22 | |
04-15-2011, 02:19 PM | #23 |
A fellow can make anything work if you apply some thought & energy toward it. Now whether you have the time it takes is another thing. Ford made it work in the later wide frame cars but the narrow frame cars required engineering the fit of the components plus any other component that might have to be worked into the mix. Currently, the alternatives are still reasonalbly priced and will save you time on the side of practicality.
04-15-2011, 02:56 PM | #24 | |
04-15-2011, 04:22 PM | #25 |
If you can get your hands on the April 1990 edition of Street Rodder Magazine there is and article on Pg 108 that might help you out. The 39 push rod arm is replaced with a fabricated arm that is 2.75" center of pedal shaft to new rod end hole. I made my own rod from mild steel pullrod and threaded both ends and used a 351C Ford rocker arm fulcrum and nut and used spherical rod end with integral post and lock nut on the other end. Even though I have a toploader hooked to a SBC this system has performed well for me for 15 years. Hope this information clears things up for you
04-15-2011, 05:14 PM | #26 |
04-16-2011, 10:51 AM | #27 | |
