Old 02-03-2013, 04:03 PM   #21
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: Driving along, then boom and crunch
Same thing happened to me in 1981 driving up to my aunts to give her a ride in the 29 spec. coupe. Took out 2 teeth in the ring gear and 1 in the pinion. What a bang! Sure knocked the dust off the floor. Had another rear end for parts so we had her back on the road the next day. Your experience reminded me, never want a repeat.
Barry B./ Ma. is offline   Reply With Quote
Old 02-08-2013, 01:16 AM   #22
dynaflash_8
dynaflash_8's Avatar
Got my spare parts and started tearing into it. Ill keep this thread updated as i go along. Also, heres some pics of my pre - 1950 traditional rpu in progress. More a Hamb canidate, but its gonna be fun. Dont worry, ol Maybell is gonna stay stock.
Broken case right by the clamshell
dynaflash_8 is offline   Reply With Quote
Old 02-08-2013, 03:29 PM   #23
1931 flamingo
1931 flamingo's Avatar
NICE shop ! ! !
Paul in CT
Old 02-27-2013, 12:27 AM   #24
dynaflash_8
so i got back to work on it. Parts ordered from synders should be here thursday. Rearend is shot. Missing teeth on a spider and locked the pinion up. That in turn broke the u joint, transmission case, sliding gear, and the clutch is shot too. Whoo!
Old 02-27-2013, 12:39 AM   #25
Joe K
Joe K's Avatar
Be curious to know how many parts are "original" and how many are modern market.
As I do up my NEXT rear end, I might choose to do a lot more "new" if there seems to be advantage to do so.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-27-2013, 12:48 AM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
This is a good time to go with the 3.27 or 3.54 ratio ring and pinion.
Old 02-27-2013, 01:11 AM   #27
Rock Hornbuckle
Rock Hornbuckle's Avatar
Dynaflash 8, I'm in Auburn also. If you wish, I would like to see what happened and offer my help with the project.
Rock Hornbuckle is offline   Reply With Quote
Old 02-27-2013, 01:32 AM   #28
dynaflash_8
Hey rock, pm sent.
Tom, im gonna need alot stouter engine before i go thinking like that :P
Joe, as far as i can tell, most parts are original, but it appears someone has had it apart before ie: mismatched bolts. all of the rivets sheared off the u joint. I picked up a rebuilt transmission complete from hogs head to clamshell, and have a good rearend. Im gonna take this oppurtunity of having the engine out to drop the pan, address some leaks, and adjust the rod caps. Also ordered a new manifold to try and get rid of that pesky exhaust leak.
Old 02-27-2013, 01:54 AM   #29
Joe K
Joe K's Avatar
All of the rivetrs sheared off the U joint
Assuming you have the earlier and original "ring" style UJ. Cross style has spring clips.
Joe K
Old 02-27-2013, 02:18 AM   #30
dynaflash_8
Joe K
i imagine so yes. Im not too studied on the differences. Its a 30' standard.
Old 02-27-2013, 04:12 AM   #31
Joe K
Joe K's Avatar
The original or first design had a circular ring with four "trunnions" formed into the ring. The input and output splines each engaged two opposite of the trunnions with two "ears." There are like 8 rivets that hold the two halves of the ring together and encircle the ears.
The later design (it started even before Model B I believe) was essentially a modern U joint with a "cross" and input and output yokes. Each yoke engaged the cross at two opposing points.
Joe K
