08-13-2023, 07:18 PM | #21 |
Re: 1935 vinyl roof insert installation
08-13-2023, 07:27 PM | #22 |
4 door top is the same as coupe/2 door except longer and more cumbersome.
Other than that, it is not a tough job if you are careful and pay attention as you go. Just be sure you are happy with the lay of the topping before making the final trim with a razor blade. Up to that point you can go back and tune it up. I attached a couple of edited pictures of some posted earlier in this thread pointing out the inner channel where the first layer of fabric is secured. I usually use a light canvas over the poultry wire to provide good smooth support for the padding. Lately; I have found that billboard membrane makes a good first layer; my trimmer friend even leaves out the chicken wire when using the membrane. |
08-13-2023, 09:48 PM | #23 |
Rich B. Billboard Membrane.
Please explain that material . Stretch |
08-15-2023, 05:50 PM | #24 |
Having a hard time finding the rubber roof insert for a 1935 Ford Slantback. What Material can i buy for a good replacement.
08-17-2023, 06:55 PM | #25 |
Thank you for posting the instructions.
If any one know what kind of material i could use that would be great. |
08-18-2023, 09:03 AM | #26 | |
Light canvas is normally used over the wire: I used heavy sign/banner/billboard material instead of wire last couple times; this material could also be used over wire if using it as an antenna. I used foam as padding; but cotton or polyester batting is commonly used also. I used marine vinyl for the topping; more original type material is (or used to be) available from the Model A parts dealers. I used Carpenter's rubber retainer strip. |
08-18-2023, 09:18 AM | #27 | |
Here is a picture of the material when he used it on a Model A another friend and I built for for his son, along with one with the material over the wood bows in my coupe. |
08-18-2023, 11:18 AM | #28 | |
08-18-2023, 03:38 PM | #29 |
Thank you to everyone for your input.
I found some material 65 inch wide sold by the foot at Snyders Antique Auto Parts .Com should work. |
