Old 08-16-2016, 04:49 PM   #1
Jimbarton
Default 51 Fordomatic torque converter hub needed
Does anyone have or know where I can locate the hub piece on a 51 Fordomatic torque converter? This would be the driver for the front pump. It seems that the 51 had a longer reach than later models. Mine had one of the ears found broken off when disassembled. Thanks...
Jimbarton is offline   Reply With Quote
Old 08-16-2016, 06:25 PM   #2
nickthebandit
Default Re: 51 Fordomatic torque converter hub needed
Try Fatsco transmission in New Jersey.
nickthebandit is offline   Reply With Quote
Old 08-16-2016, 07:00 PM   #3
Jimbarton
They show a 52 and up online but I will call to see. Thanks
Old 08-17-2016, 09:02 PM   #4
Barlea
Jim, that hub will not fit up to an 8BA crank or an 8CM crank, the '51 and later 1BA and 1CM cranks have the larger recess machined to accept the O-Matic hub. That damage could have resulted from a previous mismatch.
Barlea is offline   Reply With Quote
