01-03-2012, 01:48 PM | #1 |
B-Model Distributor w/ Modern Cap & Points, 6-volt Script Coil, Resistor.
City:
Siler City
State:
NC
Distributor was bead blasted & painted black, then rebuilt with new upper & lower shafts, weight springs, bushings, best B-style cam, modern Motorcraft points & condenser and special concave spring unique to the B distributor. Also, new dowel pin which engages the head. Assembly was checked & tuned on a Sun distributor machine and test-run on my Model A.
Can be used on 1928-1931 Model A without Pop-out style switch, plus 1932-1934 B-style engines. The 6-volt Ford reproduction script coil has only been used during the engine testing. The ballast resistor allows use of the coil with a 12-volt system. $170. Shipping: $15 for all; includes delivery receipt. Pictures would not load. Available by email. Last edited by jea777; 03-02-2012 at 08:32 PM. Reason: Cost improvement |
04-20-2013, 10:31 PM | #2 |
Re: B-Model Distributor w/ Modern Cap & Points, 6-volt Script Coil, Resistor.
[email protected] |
