07-14-2012, 04:11 PM | #1 |
Steering gear bottom seal
On my steering gear, I am using the tube style bottom plate that keeps the oil from leaking into the light switch. Is there any good reason why I should still use the thick cork seal that goes in the at the end of the worm gear?
07-14-2012, 06:32 PM | #2 |
Re: Steering gear bottom seal
no need for the thick seal, use the thin gasket on the end piece.
07-14-2012, 07:30 PM | #3 |
Thanks Pat, that is what I was thinking.
07-14-2012, 07:36 PM | #4 |
+ i wont fit center hole to small
07-15-2012, 11:05 PM | #5 |
