03-11-2021, 09:13 AM | #1 |
What year Power Steering will work in 54 Mercury
My friend has a 54 Mercury. no power steering and want to know what years will work in his car. Plus he has no idea were to start looking for the setup. I wonder what years are the same that will work. I am just trying to help a friend.
03-11-2021, 09:16 AM | #2 |
Re: What year Power Steering will work in 54 Mercury
1953 Mercury PS with a different engine bracket and crank shaft pulley (Flathead vs Y block).
03-11-2021, 09:31 AM | #3 |
In the long run a Borgeson unit will serve well over the years and run about the same price wise, maybe less by the time a used unit is rebuilt.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
03-11-2021, 02:46 PM | #4 |
Old Redneck, I have attempted to e-mail you and jackrabbit but I don't know if the messages went through. I have a few parts that will be needed for an install. Private message me?
03-13-2021, 12:19 AM | #5 |
Don't discount electric power steering. You can use your original steering box and no pump/reservoir/hoses or hydraulics under the hood! Only a small electric motor tucks up under the dash. I just adapted one to my '54 Customline. Total cost....under $200!
Here's my write-up................. https://www.killbillet.com/forum/the...ord-customline |
03-13-2021, 12:44 AM | #6 |
03-14-2021, 05:19 PM | #7 | |
How many hours to change over? Once you get the resistance set, you don't need to hardly ever adjust that, do ya? |
03-14-2021, 06:38 PM | #8 |
Very well done swap, and a great article. Thanks.
03-15-2021, 08:07 PM | #9 |
If you wanted to stay period-correct and bolt pump to a Y-block, the '55 thru '59 Ford and mercury factory power assist system will mostly bolt-on. The only things you might need to change is the idler arm and bracket and the sector arm, which would need to come from a '54 Ford or Mercury.
Your steering gearbox and steering column do not need to be changed to convert to power assist. It is completely divorced from the steering gearbox. That is not true of the Lincoln power steering system of that era. Every once in a while, you find one or a partial setup on e-bay. Last year, I sold a completely restored/rebuilt setup I had in my garage for many years. |
