Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 03-22-2014, 12:15 AM   #1
Chuckster
Default '54 239 4 barrel conversion
This post was put in the wrong forum. Sorry
Chuckster is offline   Reply With Quote
Old 03-23-2014, 08:14 PM   #2
paul2748
paul2748's Avatar
Default Re: '54 239 4 barrel conversion
Chuck - post this in the 54 + section. This section is for site questions, not technical questions
Old 03-23-2014, 08:21 PM   #3
paul2748
paul2748's Avatar
Is it a stick shift or automatic? If an automatic, use a 55 or 56 Ford 4bbl linkage for an automatic. Not sure that the Merc manifold has all the right holes but it should. The 54 Merc linkage should fit too.
Originally Posted by Chuckster View Post
Can anyone tell me what linkage will work with an original 54 Merc intake and 4 barrel Holley Teapot on a 54 Ford 239 that is originally a 2 barrel? It has been suggested by a friend that the '56 Ford 4 barrel linkage will basically fit to the pedal and kickdown rods, but I don't know...all I do know is that the linkage on my 239 2 barrel doesn't look even close to being usable on the 4 barrel intake and carb.
Old 03-23-2014, 10:36 PM   #4
Chuckster
Thanks, Paul...I will re-post this in the correct forum. I am trying to find a 54 Merc linkage and/or a 56 Ford linkage as well. Wish me luck!
