03-23-2019, 10:53 AM | #1 |
Emulsion Tube Removal
How do you remove the emulsion tubes from a Stromberg 40, 48, 97 carb. Thanks, Mike
03-23-2019, 11:49 AM | #2 |
Re: Emulsion Tube Removal
I run a small tap down inside and use a piece of welding rod to tap them out. I forget what sized tap. Sorry
03-23-2019, 02:34 PM | #3 |
I remove those tubes by running a tap into them and then with the tap still in the tube I hold the tap in the jaws of the bench vise and then gently tap the Stromberg carb body with a soft hammer those tubes always come out doing it this way. Removed many of them when converting to alky for one of the race cars i always had to open up the dump tubes to really big sizes for more speed and power good times for sure..
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-23-2019, 04:51 PM | #4 |
Ronnieroadster: Thanks for the tip. I will try removing them using the tap method. Mike
03-23-2019, 05:02 PM | #5 |
Somebody is selling a tool kit to remove them on eBay. I don't have any info on how well it works?
https://www.ebay.com/itm/STROMBERG-9...-/360403282749 |
03-23-2019, 10:56 PM | #6 |
03-24-2019, 08:56 AM | #7 |
Does anybody know if tapping threads in the tube will change its flow characteristics?
I've removed tubes before, but only to replace them with new ones. Was wondering if the old ones with the threads were ruined. |
03-24-2019, 01:18 PM | #8 |
Flathead Fever: I decided to try out one of those kits you suggested. Looks like that is the method suggested by Quickchange34. Thanks, Mike
03-24-2019, 01:35 PM | #9 |
That kit looks just like what has been described above. If you have an 8-32 tap and handle, a $1.50 for a screw, my, and washers would be cheaper. I've used the tap/machine screw method before several times. Works great.
I dig coal, which provides motivation for EVs. |
03-24-2019, 01:52 PM | #10 |
Actually 6-32!
03-24-2019, 02:04 PM | #11 |
Oops. Been awhile since I've dug my little puller out. Thanks for correction.
03-24-2019, 11:14 PM | #12 |
I will correct as well I looked at the tap I use this morning and its a 6/32 and a 6/32 screw .
03-24-2019, 11:28 PM | #13 |
Max, thanks for clarifying tap size.
I think it was nearly 15 years ago that you shared your method for pulling emulsion tubes and a few of your other secret weapons for rebuilding Stromberg carburetors with us Fordbarners.
