03-11-2024, 02:28 AM | #1 |
replace '33 fuel sender with electric sender.
Replace '33 fuel sender with a '36, '37, '38 electric sender and gauge.
( '36, '37, '38 fuel sender machine screw holes should 'line up' with the '33 tank top holes.(?) I intend to keep the '33 fuel gauge in the dash for 'looks'. Your thoughts. Thank You. |
03-11-2024, 07:54 AM | #2 |
Re: replace '33 fuel sender with electric sender.
Where would you put the new gauge since you’re keeping the old one for looks?
Tim Carlig |
03-12-2024, 07:51 AM | #3 | |
(if interested, view my other posts on this subject by key words. My orig '33 gauge that came w/the car was completely destroyed by the obviously spilled 'red' . . . corrosion, & corrosion holes through the metal case. ( I've found another '33 orig for the gauge panel. Thank You! Apparently no one has done what I am considering. |
03-12-2024, 04:02 PM | #4 |
03-13-2024, 12:43 AM | #5 |
