Old 05-21-2015, 08:05 PM   #1
Daves55Sedan
Daves55Sedan's Avatar
Default carb float
'55 Ford 2bbl carb float is full of gas. Can't tell where the leak is. Is there anyplace where you can buy a new float for Holley 2100, 94 or flathead carb? Is there anyone who can repair an old one?
Old 05-21-2015, 08:40 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: carb float
Here's how to find and fix the leak:
https://www.youtube.com/watch?v=XJmmbvTqFTA
I think the guy is Canadian but we won't hold that against him...
Dobie Gillis is offline   Reply With Quote
Old 05-21-2015, 09:55 PM   #3
parklane
parklane's Avatar
Hey, I resemble that!!
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 05-22-2015, 06:11 AM   #4
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
scicala, he's on here as well as HAMB. Sal Cicala (586) 612-1650 [email protected]
streetdreams is offline   Reply With Quote
Old 05-22-2015, 07:27 AM   #5
oj
Best to replace it. New ones are available. Problem with repairs is weight, the weight is critical. If it becomes a few grams heavier from excess solder then it'll ride lower in the fuel and that means it will take a greater amount of fuel to shut off the needle & seat.
I do a lot of carb work and have scales to weigh the floats on the older carbs.
oj is offline   Reply With Quote
Old 05-22-2015, 09:50 AM   #6
Dick's Hot Rod Place
Dick's Hot Rod Place's Avatar
I carry them in stock.
www.dickshotrodcarbs.com
Dick's Hot Rod Place is offline   Reply With Quote
Old 05-26-2015, 04:30 PM   #7
Daves55Sedan
I decided to order a new float from Dick and he also makes ethanol-safe carb gasket sets so I ordered one of those from him too. I will use those in my spare carb (Holley 2100) while I drive using the Ford EBU carb that has a Daytona parts rebuild kit in it.
Dicks prices are very reasonable too.
