07-22-2010, 07:24 PM | #1 |
engine repair
my connecting rod journals read 1.486-1.487-1.486-1.488 I have a set of new rods marked. 020 with a full shim pack will they work If I'm reading this book right .020 is 1.480 . thanks shade tree at work.
Dennis in Kelsey ca |
07-22-2010, 07:32 PM | #2 |
Re: engine repair
Sounds to me that the rods are a little small. Over fifty Years ago, I "re-fit" a set of rods that were about .010 too small. Simular situation to yours. I did not have any money for the correct rods and I had these and a good sharp bearing scraper and a lot of time. The engine ran just fine for several years until I sold the car and went into the Army. I really would not recomend this procedure but in the old days, it was done.
Chris. |
07-22-2010, 08:24 PM | #3 |
Re: engine repair
What Im Trying To build is a coffe shop motor about 24 mile round trip no long distance plans. # 4 rod journal has a piece of babbit missing in the center no damage to crank journal. I was hoping to put in a gasket set and run. No shims left
07-22-2010, 10:41 PM | #4 | |
Re: engine repair
How about a picture? It just depends on how much is missing and how good the rest of it is. If the rod bearings are really marginal, I think I would want to do something about it while it is apart. If the crank pins are round, you can buy some .010 undersize rods, take a few shims out and that should work fine. I do not like to take stuff apart after I have just gotten it together. Just my opinion, Chris |
