06-24-2015, 04:08 PM | #1 |
Is there a safe way?
Is there a safe way to disassemble a transmission tower without a $35 spring compressor? I want to see what would need to be replaced.
Then I could decide whether or not to buy a rebuilt from Snyders for $130 or invest in the parts and the spring compressor for reassembly. Thanks, Gang! Larry Jenkins |
06-24-2015, 04:15 PM | #2 |
Re: Is there a safe way?
I think that's $ 35 well spent makes the job easy and safe . I made my own tool worked perfect removing spring . But going back in not so good . But it worked then I found the tool I already purchased 4 years ago .
Dennis in Kelsey ca |
06-24-2015, 04:15 PM | #3 |
Vince shows a simple home made tool on his site.
http://www.fordgarage.com/pages/shiftlevertool.htm Bob |
06-24-2015, 04:17 PM | #4 |
Nothing better than the $2 home made version. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
06-24-2015, 05:04 PM | #5 | |
You may not have to buy anything to rebuild your tower. The detent tracks on the 2 shift rails can be welded and reground. So can the ball that moves the forks. That's what I did anyway. Your results may vary.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
06-24-2015, 05:41 PM | #6 |
06-24-2015, 06:47 PM | #7 |
06-25-2015, 12:34 AM | #8 | |
I want to make one. It looks like 3/4" Conduit, how long is the slot opening and width? How far is the washer from the end? Thanks!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
06-25-2015, 04:35 AM | #9 |
The pipe is from a piece of free exercize equipment I picked up from the curb. I'll have to find it and get back to you with dimensions, but it's just large enough to slip over the spring, and the cut down flat washer is brazed in place at a slant to match the spring coil. Nothing too specific. I cut the bottom at a slant which doesn't show too well in the picture. I put a flat washer on the top of the pipe before I slipped on the hand grip. This way the pipe won't cut through the handgrip when I push down on it.
