Old 03-06-2024, 12:30 PM   #21
dmar836
Default Re: Safety cage?
Deleted my rant but cannot disagree... even though I'm not sure exactly why you say this.
dmar836 is offline   Reply With Quote
Old 03-13-2024, 10:17 PM   #22
Russ B
Don’t know if this helps, but I had a similar concern about 30 years back. What I built for my closed cab pickup will not meet any particular safety standards, but I felt it made significant strengthening to the B pillar area and gave me a mounting point for a shoulder harness. It is simply a thick wall 3/4” rectangular tubing going up near the B pillar and crossing over to the other side. The tubing is attached midway to the B pillar with a strap and bolt. In my case, it was painted black body color and does not stand out excessively.
Russ B is offline   Reply With Quote
Old 03-14-2024, 05:05 AM   #23
Bruce of MN
Bruce of MN's Avatar
Can you post some photos?
Old 03-14-2024, 12:34 PM   #24
dmar836
Did it work?
Old 03-15-2024, 12:09 PM   #25
Canton_Model_A's
Canton_Model_A's's Avatar
hahaha
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-20-2024, 11:43 PM   #26
Russ B
i previously said it was made of 3/4" rectangular tubing, it actually looks more like 1" tubing, maybe 1-1/4"
While this is not a sedan, and instead is a pickup, you can see that it blends in reasonably well.
As it is my vehicle, not a customer's, I only have to satisfy myself that it provides a higher level of safety than a vehicle with nothing done.
Old 03-21-2024, 05:11 AM   #27
Bruce of MN
Very subtle and it blends in well.
Old 03-21-2024, 08:14 AM   #28
old31
Russ, very nice job!
old31 is offline   Reply With Quote
Old 03-21-2024, 08:55 AM   #29
Bob Bidonde
Bob Bidonde's Avatar
Many states require youngsters be strapped into an approved safety seat situated in the back seat of a car. i think at least 2 or maybe 3 of these seats could be mounted in a Model "A" Tudor.
Bob Bidonde
Old 03-22-2024, 03:51 PM   #30
Feurst choice
Good Work, Ross!
Feurst choice is offline   Reply With Quote
Old 03-22-2024, 04:10 PM   #31
Synchro909
Synchro909's Avatar
I did something very similar with my 1930 CCPU. I used 50X50X3 mm square tubing which I ran right behind the B pillar, then over the door and braced it to the A pillar. I figured I couldn't do much more than that. I mounted a safety belt on mine just as you have. Once it was all painted the same colour as the car, it disappeared.
Even though my installation is not approved (which is a requirement to be legal), I am 110% confident that I am waaaay better off than having nothing at all (which is legal). Go figure!
