Old 06-26-2019, 04:59 PM   #1
rer_239
rer_239's Avatar
Default Coil
Should both screw terminals on the coil show voltage when ignition switch is on?
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 06-26-2019, 05:14 PM   #2
Werner
Werner's Avatar
Default Re: Coil
Dick, one clamp always shows constant current / voltage. The other terminal depends on whether the breaker contact is open or closed.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-26-2019, 05:54 PM   #3
rer_239
rer_239's Avatar
Default Re: Coil
Thanks Werner makes sense if I'd stopped to think about it.
Old 06-26-2019, 06:13 PM   #4
Mulletwagon
Mulletwagon's Avatar
Default Re: Coil
If the system is unmodified, voltage should be present on both coil studs even with the ignition switch off. The ignition switch is wired between the downstream coil stud and the distro which allows the regular grounding through the points to collapse the coil magnetic field and produce the high voltage in the secondary coil winding. A modified system such as electronic ignition, negative ground, 12 volt upgrade is entirely different. On those systems the ignition switch normally supplies voltage to the coil.
Mulletwagon is offline   Reply With Quote
