Old 05-20-2019, 07:50 PM   #1
walkerlakeprinter
walkerlakeprinter's Avatar
Default Look at all the holes!
I'm removing a dented gas tank from my 1929 Coupe to replace it with a better one. I thought you would like to see all the holes drilled in my firewall somewhere along 90 years of various owners. Wondering what in the heck they were used for. See photo.
Also, when I removed the gas tank clamps, I had no idea what the four brackets with holes in them are for. I never saw anything like a wire or anything before I dismantled the car. See photo.
walkerlakeprinter is offline   Reply With Quote
Old 05-20-2019, 07:55 PM   #2
30 Closed Cab PU
Default Re: Look at all the holes!
Maybe some of the holes and the brackets for a Water cabin heater, mounting and running the water lines?
Old 05-20-2019, 08:08 PM   #3
walkerlakeprinter
I know that when I got the car, it had a push button and solenoid that powered the starter. Some of the holes are from that. Never had a water cabin heater that I know of....but in Alaska that would have been nice. Here in Nevada, an air conditioner would be nice.
Old 05-21-2019, 12:01 AM   #4
Ruth
If your "brackets with the holes" were under the tank I 'think' the brackets are to routed the cowl light wiring from the drivers side to the passenger side. I may be wrong but my Town Sedan has similar brackets and that is where the wiring is routed. rubber grommets are in the holes.
Old 05-21-2019, 12:48 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
My son had over 20 extra holes.
Old 05-21-2019, 12:50 AM   #6
updraught
updraught's Avatar
They are handy if you have a use for them.
updraught is offline   Reply With Quote
Old 05-21-2019, 01:18 AM   #7
denniskliesen
denniskliesen's Avatar
That bracket most likely for either cowl light wire, there would have been a grommet in it, or wiper motor. Did your car have a vacuum or electric wiper? Also the bracket towards the front would have had a loop to hold the top of the panel. There should have been such a bracket for both sides.
denniskliesen is offline   Reply With Quote
Old 05-21-2019, 03:15 AM   #8
johnbuckley
johnbuckley's Avatar
yes but hey're always the wrong size and wrong place!
Old 05-21-2019, 12:33 PM   #9
Gastrap
Gastrap's Avatar
Nice.
I just finished welding up 6 extra holes, plus filling an old heater hole that looked like it was made with a chisel.
Gastrap is offline   Reply With Quote
Old 05-21-2019, 12:47 PM   #10
Joe K
Joe K's Avatar
Tom W. has a nice picture showing the looped kick panel retainer up next to the firewall.
My truck has two on each side.
Joe K
Shudda kept the horse.
Old 05-21-2019, 03:42 PM   #11
CHuDWah
CHuDWah's Avatar
Originally Posted by Gastrap View Post
Nice.
The one in our Sport Coupe had "saw-teeth" all around the circumference - somebody had drilled a bunch of holes in a more-or-less circle, then knocked out the center.
CHuDWah is offline   Reply With Quote
Old 05-21-2019, 04:14 PM   #12
Farrell In Vancouver
Farrell In Vancouver's Avatar
I remember redoing the 31 AA truck cowl,- 51- holes including a 2" and an 11/2".
Took a long time and a whole bunch of plugs to bring her back to stock.
We figured the original Unit had a Hydraulic pump off the cam gear but not sure.
Farrell In Vancouver is offline   Reply With Quote
Old 05-21-2019, 04:39 PM   #13
Synchro909
Synchro909's Avatar
I keep all my spare holes in a jar but it is always empty!
