Old 07-11-2015, 03:32 PM   #1
visionary
visionary's Avatar
Default vinyl top on Tudor sedan
geting ready to replase the roof on my 30 tudor and i'm not sure if the foam padding should stop at the opening of the roof where the side rails for the bows or go all the way to where the vinyl ends where the rain gutters go?
thanks
Scott
visionary is offline   Reply With Quote
Old 07-11-2015, 03:39 PM   #2
Mitch//pa
Default Re: vinyl top on Tudor sedan
thanks
Scott
Stops at the roof opening
Old 07-11-2015, 04:18 PM   #3
visionary
visionary's Avatar
Mitch, is that black material in your picture foam or is that the muslin sheeting? i ran the sheeting to the iner roof opening, but i was woried that the foam would be to wavy and puckered up from the nails. and after the vinyl is placed over it, the outline of the roof opening would show through. so that's why i was thinking that it ran all the way down to the gutters.
Old 07-11-2015, 04:20 PM   #4
Tom from Drippin'
Tom from Drippin''s Avatar
Marco has a great tutorial on his website. "Marco's Barnyard"
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 07-11-2015, 04:25 PM   #5
Mitch//pa
Scott
It's the denim that comes in the LB kit
The padding is not thick which also came in the kit
Old 07-11-2015, 04:46 PM   #6
visionary
visionary's Avatar
Mitch do you have any pictures of the padding installed pryor to the vinyl?
thanks
Scott
Old 07-11-2015, 04:47 PM   #7
Mitch//pa
Picture 2 is the padding
The vinyl went over that
Old 07-11-2015, 04:53 PM   #8
visionary
visionary's Avatar
It looked like the second picture you posted was the vinyl material. so if thats the foam, it also goes all the way out to where the gutters atach?
Old 07-11-2015, 04:56 PM   #9
Mitch//pa
I'll pm you
Old 07-11-2015, 05:14 PM   #10
visionary
visionary's Avatar
Thanks Mitch i guess after pulling the vinyl tight any imperfections will disapear.
Old 07-11-2015, 05:18 PM   #11
Mitch//pa
Yes
I pull the vinyl tight and pin tack it with 1" temp brads. ( just barely driving them in )Then after a day or two I remove sections of the temp tacks and pull the vinyl tighter then final tack using the shorter proper brads
Old 07-11-2015, 06:36 PM   #12
Jwilli
Jwilli's Avatar
I just finished installing a new roof on my late 31 tudor. Marco's tutorial was extremely helpful. Mine don't look as good as his, but is far better than if I had not had his instructions to follow. Thanks Marco.
Jwilli is offline   Reply With Quote
Old 07-12-2015, 12:08 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I prefer cotton to the foam, as foam will break down with age and heat. I saw a couple roofs that had a very puffy look because someone used padding that was too thick.
Old 07-12-2015, 01:28 AM   #14
Mitch//pa
Agree it's not foam, that will look terrible
Cotton padding is supplied with the LB kit
Old 07-12-2015, 04:52 AM   #15
aermotor
Do ya all trim the vinyl before or after installing the track strips for the trim and drip rail?
aermotor is offline   Reply With Quote
Old 07-12-2015, 06:11 AM   #16
Mitch//pa
Trim before the gutters are installed, otherwise you'll see the vinyl and screw the paint job up
Old 07-14-2015, 05:21 AM   #17
aermotor
Pros and cons of cotton wadding vs. urethane foam padding please.
John
Old 07-14-2015, 06:24 AM   #18
Mitch//pa
Tom answered that in post #14... It won't compress or compress evenly so you will have unevenness especially over the roof bows and side areas where there is not the same give as the center areas where there is just chicken wire
Old 07-14-2015, 06:52 AM   #19
Tom Wesenberg
John
Notice how so many of the newer cars have headliners that detach from the board and fall down since cars stopped using metal bows to hold the headliners in place. At first I thought it was due to poor glue, but after looking at them I see it is the foam had deteriorated and separated.
I'd stick with cotton for the top padding, and horsehair and other materials for seat padding. I think the best use for foam is for packing when you mail glassware.
Old 07-14-2015, 07:28 AM   #20
aermotor
Cotton it will be - thanks.
John
