Old 03-27-2021, 10:21 AM   #1
cjs1958
Default 53 cam for auto
I just started working on a 53 Sunliner (heavy) with a Fordomatic. I'm going for a .020 overbore on original flathead. I'm rebuilding the motor to appear all stock, but would like to bump HP with a better cam if possible. My stock cam is bad. The fella helping me with the motor says if I go with a performance cam, my automatic won't shift right. Anybody have any thoughts or experience with this. Any suggestions for cam, or someone to regrind mine? Thanks.
cjs1958 is offline   Reply With Quote
Old 03-27-2021, 10:26 AM   #2
JSeery
JSeery's Avatar
Default Re: 53 cam for auto
Unless you make a lot of other modifications to the engine, just about any aftermarket cam will reduce performance. The later stock cams are about as good as they come for this application IMO. One thing that will really help is uping the compression ratio by reducing the clearance between the piston and the head to around .050. If you can not locate a good original cam, there are several cam grinders here on the Barn that should be able to grind you one.
And welcome to the Barn!
Old 03-27-2021, 11:25 AM   #3
tubman
tubman's Avatar
I was considering putting an Isky Max-1 cam in the '51 Merc that went into my '51 coupe (also a relatively heavy car), and after much research and discussion, stayed with the stock Merc cam. Also, I am a real fan of an 1/8" overbore on these engines. This will yield 258 ci, 3 more than the vaunted 4" Mercury crankshaft. I figure that if the Ford engineers considered the expensive option of an entirely new crankshaft and pistons was justified because of the increased weight of the Mercury's, why not take the much cheaper (if not free) option of a safe overbore? Just about all of these engines will go out to 3 3/8" with no problem, so 1/8" leaves room for further corrections. If you need new pistons anyway, why not go the extra for about the same piston cost?
Old 03-27-2021, 12:35 PM   #4
tubman
tubman's Avatar
I also agree with "JSeery" about optimizing the "squish" between the piston crown and head. On the first couple of engines I built (pre "Ford barn"), I just threw on a set of "Hi-Compression" heads without checking and was always slightly disappointed with their performance. (I have less confidence about the manufacturers holding tolerances than I was then.) On the last two, I have spent quite a bit of time optimizing the piston/head clearance and have been much more satisfied with the results.
A small base Rochester carburetor on a bored out Mercury manifold results in a nice street engine with a notable increase in power without busting your budget.
Old 03-27-2021, 12:47 PM   #5
Desoto291Hemi
Hi Denny ,
I am planning on taking your advice on the carb and manifold combo .
I was just going to ask you what carb you used,,,,and exactly what size you bored the intake to .
I’m leaning towards keeping my stock Mercury intake after all .
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 03-27-2021, 01:08 PM   #6
tubman
tubman's Avatar
Tommy,
Rather than cluttering up this guy's thread, I'll send you a PM.
Denny
Old 03-27-2021, 01:24 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by cjs1958 View Post
I just started working on a 53 Sunliner (heavy) with a Fordomatic. The fella helping me with the motor says if I go with a performance cam, my automatic won't shift right. Anybody have any thoughts or experience with this. Any suggestions for cam, or someone to regrind mine? Thanks.
The only issue I can visualize using a performance cam with the FordOmatic is if using one requires a higher idle speed.
The FordOmatic is generally set to 500 RPM or less.
Get a good stock Ford or Mercury cam.
Old 03-27-2021, 04:43 PM   #8
mfirth
8CM Merc cam is ideal imo.
mfirth is offline   Reply With Quote
Old 03-27-2021, 06:21 PM   #9
Grease348
Grease348's Avatar
I’m still gathering parts but I got a Canadian aluminum four bolt intake and a 1956? Rochester 2gc carb.
Grease348 is offline   Reply With Quote
Old 03-27-2021, 08:05 PM   #10
cjs1958
Thanks for the info. Is the Merc cam more lift or duration or both? How can I find the guys on the barn to get cams from? I see a swap area, is that where I should be looking? I've been doing a lot of reading and I was planning on going with .050 clearance on heads. I would like to build a hotter motor but I think this car needs to stay close to stock. Thanks Guys I appreciate the information.
Old 03-27-2021, 08:14 PM   #11
JSeery
JSeery's Avatar
A lot of the posters on the Barn are also parts vendors, rebuilders, shop owners, etc. One that grinds cams is Pete.
https://www.fordbarn.com/forum/member.php?u=2
You may have to increase your number of post before you can contact Barn members. I think you have to have at least 10 post, it may be 20.
Old 03-27-2021, 08:27 PM   #12
JSeery
JSeery's Avatar
Both. Here are some of the early Ford cam specs.
Old 03-27-2021, 08:40 PM   #13
tubman
tubman's Avatar
I have this same setup on my '51 and it works very well. I used a Rota-Broach in my drill press to bore the manifold to 1 7/16" to match the Rochester carb. The increase in the area of the throttle bores is in the neighborhood of 30%. It's even greater when replacing a Ford 3 bolt carburetor.
If you would like to see it, I could send you a copy of the PM I am sending to Tommy.
Old 03-27-2021, 09:46 PM   #14
swedishsteel
I have a cam that has cast "1cm" on it--is it the same as an 8cm? Was in a block with 8cm heads and 4" crank, rotators valves. Searched and can't find anything about it.
swedishsteel is offline   Reply With Quote
Old 03-27-2021, 10:10 PM   #15
Ol' Ron
Ol' Ron's Avatar
I would deffinately bore to 3 5/16. this will at aprox 20 ci and a poiin compression. Best cam would be a 52/53 EAB stock cam, which was made for the auto.
Gramps
Old 03-27-2021, 10:18 PM   #16
cjs1958
Yes I'd like to see it
Old 03-27-2021, 10:36 PM   #17
tubman
tubman's Avatar
"1CM" was the designation used on new for 1951 parts. I don't know much more than that, but I would guess that Ford engineers may have changed the profile a bit to accommodate the new for 1951 Merc-o-Matic transmission. If I had to guess, I would say that it would be a little milder than an "8CM" because of the idle requirements of the automatic transmissions.
I am now aware of 4 distinctly different 8BA type cams : (8BA, 8CM, 1CM, and EAB). There may be more. It sure would be nice if someone could find the definitive specifications for these (and any others). It would be an interesting comparison.
Old 03-28-2021, 12:40 AM   #18
Phil Gillespie
Phil Gillespie's Avatar
As per JDL 08-10-2010.
Cam Specs.
Default Re: 53 Mercury camshaft
49-51 ford "B" cam
.305 lift
int. opens 5*btc - closes44*abc set.017
exh. opens 48*bbc -closes3*atc set.019
52-53 ford "E" EAB cam
.328 lift
int. opens 21*btc - closes68*abc set.017
exh. opens 56*bbc - closes11*atc set.019
49-50 merc "8CM" cam
.338 lift
int. opens 10*btc - closes50*abc set.014
exh. opens 50*bbc - closes10*atc set.016
51-53 merc "1CM" cam
.333 lift
int. opens 5*btc - closes51* abc set.017
exh. opens 47*bbc - closes9* atc set.019
I used the above as a reference along with Tilden Specs.
I settled upon a NOS 1CM cam for a stroker engine 285cu".
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 03-28-2021, 05:58 AM   #19
Ken Henry
Ken Henry's Avatar
Is the EAB duration really 20* more for intake than exhaust?
Ken Henry is offline   Reply With Quote
Old 03-28-2021, 12:01 PM   #20
tubman
tubman's Avatar
Thanks Phil, that's good information. It looks like the 1CM was detuned slightly from the 8CM as I guessed. One minor question; did the '52-'53 mercury's use the 1CM cam or was there a separate "EAC" cam for them? Also, is there such a thing as an "8RT" cam?
Looks like the 8CM is the "best" stock for cam given the information we have (the highest lift, at least).
