Old 09-05-2015, 11:24 AM   #41
DJ S
DJ S's Avatar
Default Re: Go ahead and give this thread a one-star rating. Babbitus fragmentus!
Originally Posted by Y-Blockhead View Post
Newbie questions... What's the recommended milage between center main bearing adjustments? Or how do you determine when you need a center main bearing adjustment?
That's a good question... I have no idea. 20,000 miles? That's just a guess...
DJ S is offline   Reply With Quote
Old 09-05-2015, 12:00 PM   #42
Tom Wesenberg
Tom Wesenberg's Avatar
It would depend on how fast you run the engine, how often you change the oil, and whether or not you have a counterweighted crank.
Old 09-05-2015, 12:44 PM   #43
George Miller
George Miller's Avatar
It will let you know when it is time. There is no right answer to your question on how long. It depends on a lot of things. How good was the babbit job, how fast do you drive, was it adjusted right in the first place, do you lug it on the hills, do you use the spark lever correctly and so on.
George Miller is offline   Reply With Quote
Old 09-05-2015, 12:51 PM   #44
George Miller
Default Re: Babbitus fragmentus!
I had a 1930 Townsedan that had 85,000 miles on it when I adjusted the mains and rods and ground the valves for the first time.It was a original car with the original engine. I might say it was real smooth also. Also no sludge in the engine.
Old 09-08-2015, 02:20 PM   #45
TDO
TDO's Avatar
Originally Posted by PC/SR View Post
Try a presurized center main. Dennis Pirano in Tx has a kit, cheap and easy to install. Its a simple installation.
How do you contact Dennis Pirano in TX. ?
TDO is offline   Reply With Quote
Old 09-08-2015, 11:44 PM   #46
PC/SR
Here is the link to his website. He used to list parts, but I guess you have to call him now. http://www.perfenginc.com/parts.htm/partsdept.htm
PC/SR is offline   Reply With Quote
Old 09-09-2015, 04:11 PM   #47
updraught
updraught's Avatar
Seems to take some machining:
http://www.modelaparts.net/special.h...entermain.html
updraught is offline   Reply With Quote
Old 09-09-2015, 10:44 PM   #48
PC/SR
Does not require any machining. You need to drill and tap the center main cap, and the block for the fittings, with a drill into the oil passage. Its an easy job.
