Old 12-25-2012, 10:30 PM   #101
vintagevolks55
Default Re: 1935-1941 Ford Pickup Parts
you wouldnt happen to have any complete 1940-41 trucks would ya? looking for a project, and im also a vw guy, got any vws sitting around?
thanks
danny
vintagevolks55 is offline   Reply With Quote
Old 12-26-2012, 07:27 PM   #102
jvanhoover
Hey, do you have any 1935 1 1/2 ton truck parts. Looking for a steering wheel. well the whole column if you had one. Any doors for the cab? thanks
jvanhoover is offline   Reply With Quote
Old 12-30-2012, 09:30 PM   #103
Drifter
How much for the 38 p/u grill in the picture? is the center strip on it?
Drifter is offline   Reply With Quote
Old 01-24-2013, 07:41 PM   #104
[email protected]
Originally Posted by Aircooled1 View Post
I have early 1935 through 1941 Ford 1/2 ton pickup parts available,from frames cabs fenders & beds to hoods grills & doors,banjo rear axles & transverse spring front axles to 16" wheels & early hydraulic brakes,flathead V8 motors & parts to top loader transmissions & parts,ask and I may possibly have the part you are looking for, EMAIL FOR PICTURES, located 125 miles North of Sacramento on Highway 99, email [email protected] or call 530-384-1651
am looking for a nice 35 pu grille steve
denton34@cox.net is offline   Reply With Quote
Old 01-30-2013, 09:48 PM   #105
Boss1940
I am looking for a upper rad / grille support for 1941 ford pick up. 6 cylinder. It would be the part that the hood latches down on.. Tom. 1-732-647-6128
Boss1940 is offline   Reply With Quote
Old 02-01-2013, 07:02 PM   #106
BC Texas
Looking for late 46 or early 47 ring and pinion set, for open drive banjo rear. 3:78 or 4:11 has the yoke, not the spline
BC Texas is offline   Reply With Quote
Old 02-05-2013, 11:23 PM   #107
BLACKFLAMED50
I'm looking for a pair (or left side) hood hinges for 1938-39 Pick-up
BLACKFLAMED50 is offline   Reply With Quote
Old 02-06-2013, 05:51 PM   #108
40fordpu
40fordpu's Avatar
How about 40 horns?
40fordpu is offline   Reply With Quote
Old 02-10-2013, 08:58 PM   #109
aldixie
Looking for 38 thru 41 Gas filler tube. Thanks
aldixie is offline   Reply With Quote
Old 02-21-2013, 07:53 AM   #110
JLB3
Looking for 37 Ford Pickup parts. PM or email me at JLBThreee at gmail dot com
- Grill Trim
- Hood Side and Front grill emblem
- Right side door mirror
- Running board spare tire holder
JLB3 is offline   Reply With Quote
Old 03-11-2013, 08:30 PM   #111
hdleaksoil
Originally Posted by ken ct View Post
Why some people have to bump,bump,bump constantly is beond me. Once should be enough.?????????????????? ken ct.
What does it cost for you to rebuild my 40 carb ??? thanks len
hdleaksoil is offline   Reply With Quote
Old 03-13-2013, 08:42 PM   #112
nixtochevy
i need a pass side door for my 35 pick up....i don't know early from late..can i get a picture of them?? [email protected]
nixtochevy is offline   Reply With Quote
Old 03-16-2013, 10:42 AM   #113
Aircooled1
Aircooled1's Avatar
Bumping to the top of the list is supposed to be allowed every 3 days according to the Ford Barn rules.....check them out yourself.....Jim A.
Aircooled1 is offline   Reply With Quote
Old 03-22-2013, 03:41 PM   #114
timlreed
If you can help me , i sure do need a pair of 1938-1939 ford pickup hood hinges . these are very hard to find . Thanks
timlreed is offline   Reply With Quote
Old 05-21-2013, 10:04 AM   #115
pig boat
aircooled, i need the front grill aprons for my 1938 ford truck.. between the grill and fenders. thank you . please notify at [email protected].. Jack
pig boat is offline   Reply With Quote
Old 05-22-2013, 08:53 PM   #116
V12Bill
V12Bill's Avatar
Looking for 1938 or 39 pickup radiator stamped 81 C. [email protected]
Would like to get a shroud also , but not urgent.
V12Bill is offline   Reply With Quote
Old 05-31-2013, 11:26 PM   #117
colondaddyof3
Hello I need a 1937 truck grill, rear fenders, a bench seet, a bed and more,, let me know how much for the short list,,,thanks
colondaddyof3 is offline   Reply With Quote
Old 06-06-2013, 12:34 PM   #118
dinokruzordinance
dinokruzordinance's Avatar
Aircooled the grill and the fenders on a 1.5 1937 are larger / bigger radius. Is the cab the same as 1/2 t? Will 1/2 fenders mate to a 1.5 ton? My 1/2t has a despicable crush spot in the B pillar and I have a 1.5. Do u have that 1/2 fender still? I read roothawgs tech post but am unclear on the above
dinokruzordinance is offline   Reply With Quote
Old 06-16-2013, 02:03 PM   #119
Coreyfatboy
Coreyfatboy's Avatar
Do you have a steering box for a 36 pick up?
Coreyfatboy is offline   Reply With Quote
Old 06-16-2013, 08:01 PM   #120
gerrald meacham
need dual bottom pully for 24 bolt ,38-40 ford big truck
gerrald meacham is offline   Reply With Quote
