Old 10-21-2019, 02:09 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Lube ??
Customers unit for test only. Unit was so dry my distributor machine didnt want to turn it , points are oxidized from setting etc.
Clean , lube with Mobil 1 wheel bearing grease and Marvel oil , brass brush with dremel on contacts , polish with dollar bill. Lube dry leather vac brake and lube then reassemble and run for some time on tester .....works prefect !!!!!!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-21-2019, 02:43 PM   #2
RKS.PA
RKS.PA's Avatar
Default Re: Lube ??
Jim, "a thing of beauty is a joy forever!"....you can quote me on this one! Nice work by you as usual!
RKS.PA is offline   Reply With Quote
Old 10-25-2019, 10:26 AM   #3
Ritzy1
Ritzy1's Avatar
Default Re: Lube ??
Jim, I remember watching you lube my crab distributor when you were testing it for me. Maintenance manual suggests cam lobes should be lubricated fall and spring with original points setup. I've got a Pertonix kit, any periodic lubrication I should be performing?
Ritzy1 is offline   Reply With Quote
Old 10-25-2019, 12:01 PM   #4
petehoovie
petehoovie's Avatar
Default Re: Lube ??
Nice close-up picture you posted there, Bubba....
Old 10-25-2019, 12:11 PM   #5
BUBBAS IGNITION
Default Re: Lube ??
Finally got it figured out (thanks to you ), as a trainer for Allen Testproducts and then Linder Fuel Injection i always used the biggest slide view i could get for better explanation. Hated those little unclear pics some trainers used .....
[email protected]
Old 10-25-2019, 12:24 PM   #6
petehoovie
petehoovie's Avatar
Default Re: Lube ??
"i always used the biggest slide view i could get for better explanation."
Old 10-25-2019, 01:26 PM   #7
BUBBAS IGNITION
Default Re: Lube ??
the pertronix doesnt have a load on the cam so its more than likely lube free.....
[email protected]
Old 10-25-2019, 02:27 PM   #8
BUBBAS IGNITION
Default Re: Lube ??
We been having the camera wars between my Canon 16. meg and my grandsons I-Phone etc......I think i am winning but maybe not ????????Damn technologies ......
[email protected]
Old 10-25-2019, 04:25 PM   #9
Fordestes
Default Re: Lube ??
Do you suggest removing the end plug and soaking the felt periodically ? also what is the best lube for the shaft felt wicking?
Fordestes is offline   Reply With Quote
Old 10-25-2019, 06:55 PM   #10
BUBBAS IGNITION
Default Re: Lube ??
Used to do it to all we built, then after a few hundred decided it was more trouble than its worth. The orginal design seems to work forever. I lube the bushing very well and when removing the plug i used Marvel Mystery oil.....Seems to work very well and i have some out there with some heavy miles on them.....
[email protected]
