Old 05-15-2018, 06:54 PM   #1
Nlbloch
Default stuck radiator cap
I have a thermostat-style radiator cap that became badly corroded. I have soaked it in CLR and most of the corrosion dissolved, but I still have some crust that just won't disappear.
Worse yet, the hinged top won't open -- I can only access the radiator by taking the entire cap off.
Any suggestions on how to remove the remaining crud, and how to separate the top/bottom parts of the cap?
Nlbloch is offline   Reply With Quote
Old 05-16-2018, 07:31 AM   #2
chap52
chap52's Avatar
Default Re: stuck radiator cap
I would try soaking it in Apple Cider Vinegar for a couple of days.
Old 05-16-2018, 07:49 AM   #3
JBill
White vinegar.
JBill is offline   Reply With Quote
Old 05-16-2018, 07:52 AM   #4
ryanheacox
ryanheacox's Avatar
If you know anyone with an ultrasonic cleaner that would probably do the trick also
