02-01-2017, 10:40 AM | #1 |
3rd member fill hole
If the rear end is filled to the hole, will it be too much. Book has 1 1/2 pints.
02-01-2017, 11:21 AM | #2 |
Re: 3rd member fill hole
I have not measured how much I put in, I just fill it to the bottom of the hole. With it at that level, I can check it and be sure it has oil. If it is below the hole and can't be reached, who knows how low it is?
This has been the standard for as long as I have worked on cars (Long time). |
02-01-2017, 11:27 AM | #3 |
You can stick your pinky in the hole to feel the oil level below the fill hole.
Regards Chris
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
02-01-2017, 11:30 AM | #4 |
I squeezed almost a quart in and its still below the hole. Plus, I have a drip I didn't have before. I thought I might have over filled it.
02-01-2017, 12:10 PM | #5 | |
So check the shop manual when servicing your differential. |
02-01-2017, 01:40 PM | #6 | |
be aware if your trans leaks it can "overfil" the rearend.
02-01-2017, 02:45 PM | #7 |
When I first checked Minervas' rear end, it was WAY overfilled, trans was OK.
HOW did someone do that???? When I first checked Vermins' stuff, the trans & diff contained ONLY 1/8 cup, in each???? Did someone DIE while waitin' for the PONY EXPRESS??? Bill Puzzled
02-01-2017, 05:11 PM | #8 |
When the previous owner of my '30 CCPU delivered it, he had had it serviced by a modern Ford dealership in AZ. I won't go any further to identify the dealer but the rear end was bone dry. I'm sure they didn't have the tool to undo the plug - the Mitchell O/D was also very low and it has the same plug. I have flushed the rear end till the sparkly bits just about disappeared from the flush, filled with my usual oil and it has been OK since. I intend replacing the bearings at least as soon as I can but it does show how tough these things are. I think having the oil level a little high or low won't be the end of the world.
PS, I could type a page listing the other stupid things that modern dealer did.
02-01-2017, 05:37 PM | #9 |
Fill it to the hole...different books and manuals state different amounts...
If you have a leak see where it is coming from as at that level it should be dry |
02-01-2017, 08:12 PM | #10 |
tick!
02-01-2017, 08:50 PM | #11 | |
02-02-2017, 12:16 PM | #12 |
If the oil level is below the bottom of the hole, I just use a bent wire to find the level.
I was taught that the oil level can be a long way down and there's still enough in there to get thrown around by the ring gear to lube everything.
02-02-2017, 12:25 PM | #13 | |
Be safe and keep clean fluid up to the fill hole. |
02-02-2017, 12:26 PM | #14 | |
02-02-2017, 07:59 PM | #15 |
Here is a list i had compiled previously on the capacity spec for the rear differential
diff capacity: different info from different sources:: brattons 1.5 pints snyders 2 qts les red book 2-1/4 pints service bulletins 1.5 pints --page 227 service bulletins 2 qts --- page 375 tams 1.5 qts macs 1-1/2 to 2 qts berts 3 pints Last edited by Mitch//pa; 02-02-2017 at 08:05 PM. |
