Old 10-08-2018, 01:57 AM   #1
quickchange
quickchange's Avatar
Default Mitchell gear spiters,
As a fan of Mitchell over/drives (gear splitters) having sold & fitted a number also visited their factory twice , Got to know the family well , I was concerned today that a rumour was circulating that some recently made ones have been giving troubles .This surprises me & was wondering has any one had any problems ?? feel free to mail me on this, I will also contact Sue with the same concerns , Why am I concerned, well customer called he had heard from a reliable source & wished to cancel his order , That's no problem but any untruths are , particularly on such a great unit , Look forward to your replies ,
quickchange is offline   Reply With Quote
Old 10-08-2018, 06:53 AM   #2
old31
Default Re: Mitchell gear spiters,
Must be fake news from a competitor.
Old 10-08-2018, 11:21 AM   #3
Jim Brierley
I always question "reliable sources"!
Jim Brierley is offline   Reply With Quote
Old 10-08-2018, 03:00 PM   #4
AL in NY
AL in NY's Avatar
If it's fake new from a competitor, which competitor would that be, since Mitchell makes the only OD for a Model A.
AL in NY
AL in NY is offline   Reply With Quote
Old 10-08-2018, 03:26 PM   #5
quickchange
No not a competitor, He is a parts dealer here & I can speak very highly of him , Will get to see him this week end & ask him to authenticate his comments, Thanks,
Old 10-08-2018, 03:36 PM   #6
MAG
MAG's Avatar
The only problem I have seen with a Mitchell is the clearance of the OD section on Vicky bodies.
The OD section is as far forward for this body style as it can be but the box will hit the recessed floor when going over bumps. Mitchell is aware of the situation and suggests adding additional leaf(s) to the rear spring to alleviate the condition.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 10-08-2018, 04:26 PM   #7
updraught
updraught's Avatar
Transmission needle bearing failure?
updraught is offline   Reply With Quote
Old 10-08-2018, 04:48 PM   #8
quickchange
Updraft, Yes that's what I believe & someone has got confused , Mitchells are great folk to deal with,& produce a great product which adds value too your vehicle, My land speed record holder Lickity Split Model A cpe runs a Mitchell trans , Thanks
Old 10-08-2018, 06:58 PM   #9
lee in bend
lee in bend's Avatar
MAG, I purchased a Mitchell specifically for my Victoria. Yes, the regular ones do interfere with the drop down floor but they do make an O/D for the Victoria by changing the lengths of the torque tubes. The O/D I purchased didn't go into my Victoria but I put it in a "31 Roadster...works perfectly.
Always Learning about Model A's
1929 Standard Roadster
1931 Deluxe Roadster
1976 Triumph Spitfire 1500
lee in bend is offline   Reply With Quote
Old 10-08-2018, 07:53 PM   #10
MAG
MAG's Avatar
I wouldn't attempt to put a regular Mitchell OD in a Vicky or 400A. The one made for these two body styles moves the box as far forward as it will go. The radius rods prevent it from being moved any farther forward. But it is still so close to the dropped floor it can hit it. Have installed several Mitchells without any trouble except with this body style.
Old 10-08-2018, 09:31 PM   #11
Bick in New Zealand
Bick in New Zealand's Avatar
Haven't heard of any problems with O.Ds but know of two locals who had problems with their transmissions.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 10-08-2018, 10:21 PM   #12
Synchro909
Synchro909's Avatar
I've had no trouble with any of the three I own, except for the interferance between the curtain box under the floor and the unit on my Phaeton. Once I remodelled that, I had waaayyyy more under floor storage than before.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-09-2018, 11:07 PM   #13
daveymc29
daveymc29's Avatar
No O/D problems. With the tranny in my roadster I have to hold it in third on a steep downhill section but that is not a problem. It will jump out if I forget, so I have something to make me remember what I'm doing. Works real well in all other situations and if it bothered me, I would take it back, or pull the tower, whatever. But it really doesn't bother me. I've had old Fords that required real strength to hold them in gear and just drove them knowing what I had to do. Mitchell's are good products.
daveymc29 is offline   Reply With Quote
