07-19-2018, 10:13 AM | #1 |
Door Latch Spring
I am in need of a door latch spring for a 1939 Woodie. Does anyone have a source for them? Thanks.
07-19-2018, 10:23 AM | #2 |
Re: Door Latch Spring
Try barnfind08 here on the Barn. Fred might have a NOS one.
Making the simple complicated for over 30 years. |
07-19-2018, 11:09 AM | #3 |
Thank you. I will.
07-19-2018, 01:29 PM | #4 |
The place I found door latch springs for my '46 Station Wagon was an old time auto parts store. The owner pulled out a box that was about 18" square and on the inside of the lid was listed almost every car they were used on. Charged me a buck each.
07-19-2018, 02:03 PM | #5 |
I have already tried one that is about 45 miles from me & they said they have nothing.
07-19-2018, 03:25 PM | #6 |
07-19-2018, 07:57 PM | #7 |
Thanks Deuce Lover. I'll check them.
07-19-2018, 08:00 PM | #8 |
None that will work in a wagon...regardless of what he advertises.
07-20-2018, 11:33 AM | #9 |
If you post a picture of what it looks like I might have something. I have an old box of door springs I can look at.
07-22-2018, 04:52 AM | #10 |
07-22-2018, 06:17 PM | #11 |
Barnfind08 is a good choice. Fred is in MN. You really don't want any new repop ones. I got one of Roy's, wasn't even close. The guy who has boxes of old NOS ones is Ray Helgers in RI. I took my old spring from the '40 to him and we matched it up with ones he had. If you are not in a real hurry, get the spring out, call Ray 401 635 4849, and mail it to him to be sure get the right one.
07-22-2018, 06:33 PM | #12 |
I have a couple of boxes of those springs if all other options fail. I would need to see a picture of it though. Color also helps.
07-23-2018, 05:43 PM | #13 |
Here are a couple of pictures of the spring if anyone can match them up. No color is left on it.
07-23-2018, 06:44 PM | #14 |
I won't be home until Friday afternoon, but will check my box of unidentified, new springs when I return.
07-23-2018, 07:22 PM | #15 |
Thanks TagMan.
07-27-2018, 02:17 PM | #16 |
Woodie1,
Just got home and went through my box of springs. Sorry, but I don't have it. Some pretty close, but nothing exact. -Bob |
07-28-2018, 11:43 AM | #17 |
I went through my two boxes also and found some close in shape but not exact. What is the thickness and width of the spring material? Also, I assume the spring in picture one is in a non tension position. Spring in picture two that is broken would have the broken tang pointing up (vertical). Is that correct?
07-31-2018, 07:24 PM | #18 |
You are correct Flathead4d. I did manage to get a Model A Ford latch spring to work.
08-01-2018, 09:09 AM | #19 |
Glad you found something to work. Where are you located on the West side? I'm just south of Detroit (downriver).
08-01-2018, 07:28 PM | #20 |
North of Muskegon.
