Old 06-20-2019, 10:08 AM   #1
gridleak
gridleak's Avatar
Default Electrolock?
This ignition cable is marked with the ford logo and number g382264. The distributer end is longer and has an integral cast iron hole to attach to the head bolt. Was this used on a specific A or was it an add on?
gridleak is offline   Reply With Quote
Old 06-20-2019, 10:11 AM   #2
Will N
Will N's Avatar
Default Re: Electrolock?
The electrolock with the long "banana" end piece with the integral clamp for bolting to the head was used for very early '28s
Will N is offline   Reply With Quote
Old 06-20-2019, 10:13 AM   #3
Bob C
Sounds like the banana type end used thru May 1928.
Bob
Old 06-21-2019, 04:12 AM   #4
Werner
Werner's Avatar
Gridleak, please is it posible, to show me a picture? I am interestet allways to see old original parts. Thank you in advance!
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 06-21-2019, 11:09 AM   #5
Bob C
Early banana cable.
Bob
Old 06-21-2019, 11:16 AM   #6
Ed in Maine
I know I am very fussy about the way I do things but why are all those loose parts placed on top of the head with open spark plug holes??? Ed
Old 06-21-2019, 11:52 AM   #7
Bob C
Don't know just a picture I found doing a search.
Bob
Old 06-21-2019, 01:57 PM   #8
Purdy Swoft
Purdy Swoft's Avatar
I thought the same thing .
Old 06-21-2019, 03:09 PM   #9
Werner
Werner's Avatar
I understand right, it means the hole distributor? Like the picture from my car?
Werner
Citroen 11 CV, 1947
Old 06-21-2019, 03:58 PM   #10
F.M.
No, The Cable going to it.. And it is a 1928 Dizzy !!
F.M. is offline   Reply With Quote
Old 06-21-2019, 05:08 PM   #11
Synchro909
Synchro909's Avatar
The "banana" is the solid curved tube (not the spiral wound cable) between the distributor and the head stud holding it in place.
Old 06-21-2019, 05:29 PM   #12
F.M.
If you knew that, Why ask the ??.. P.S. Its all made together, and that is just a considered name Vs. all the rest made..
Old 06-21-2019, 06:03 PM   #13
31Cabriolet68-C
31Cabriolet68-C's Avatar
OK, FM,
So who are you actually directing your question to in Post # 12??? Was it meant for the OP, was it for Synchro99, was it for Werner (who has English as a.second language)? And while I'm on the way-off-topic subject of considering confusing language, what do you actually mean by the expression "... just a 'considered' name?
Actually, I'm fairly well ready for Happy Hour right now, so need to answer... Didn't mean to be a bother.
Hopefully I don't seem rude.
Thanks
31Cabriolet68-C is offline   Reply With Quote
Old 06-21-2019, 06:05 PM   #14
Synchro909
Synchro909's Avatar
Huh??? What ???
Old 06-21-2019, 06:29 PM   #15
31Cabriolet68-C
I meant to say NO need to answer......
Old 06-22-2019, 11:22 AM   #16
Werner
Werner's Avatar
Ok, now I understand what's called "banana". I have not known this component as cable protection yet. At that time heartily constructed! Thank you for your good advice!
Werner
Citroen 11 CV, 1947
