#1 |
Hey, Guys,
A friend went to torque the rear hub nut and stripped the axle. He is now trying to find a whole rearend for his '30 coupe. I told him there is a threader that you can clamp on the axle and chase the threads. He says the axle is too small and worn to accomplish this. I asked him if he is going to replace the shaft, as I know where there is a spare one in our club. He said he was told that you would have to replace both shafts and the gears in the rear as you shouldn't mix new gears and old gears. (I'm not going to tell anyone how to fix their car) Is it right that you shouldn't replace only one shaft? Marty |
#2 |
Replacing one shaft has been done a million times. If he wants to replace everything make sure to grab all the good parts he is removing!
#3 |
Like the fellow above says a single axle on a Model A has been replaced thousands of times, maybe millions. Another Model A myth about matched sets. Find a better original axle and use it to replace the defective one. Make sure the threads are good and the key slot is not deformed and there are no cracks around it. The gear end is not a big consideration as it is a loose fit with the spider gears.
Attached article is how to go about the task. Tom Endy |
#4 |
Tell him to replace the one shaft. The gear on the end of the shaft turns very slowly only enough to make up for the difference in the radius when turning a corner. Tell him to measure the thickness of the gaskets on the housing when he takes the rear end apart as they determine the adjustment for the rear end and MUST be replaced with the same thickness assuming the wear pattern is good on the ring and pinion gears. I would have both axles magna fluxed for cracks while it is apart.
Charlie Stephens |
#5 |
As Tom said it has been done millions of times. I would absolutely use this as the opportunity to inspect every part of the rear axle including bearings and axle shaft on the other side as well and replace all parts that need to be done, set clearances as per Tom's instructions or Les Andrews, your choice. If I was doing this on the road I would fix the one that needs to be done and get back. If doing in the shop I would do it as a thorough rebuild.
Larry Shepard |
#6 |
#7 |
My friend just called to say that he is going to do what Curtis did. Make the shaft smaller and rethread. I think I would replace the shaft. Just saying.
Marty |
#8 |
Do the most or do the least, interesting juxtaposition. I wonder if a metric size might be a compromise for diameter?
#9 | |
![]() Quote:
I would impress upon them not to do that. I had an axle break when I was in the smokey mountains and 3 hours later I was back on the road. I pulled the drivers side backing plate and radius included and had it done quick. I would suggest they fix the one axle as as the smaller thread diameter is risky at best with the proper torque required. Is his life not worth that much if the wheel comes off? Fix it right! Would he travel with only two lug nuts? It's the equivelant of that. Larry Last edited by larrys40; 10-31-2017 at 03:00 PM. |
#10 | |
![]() Quote:
Charlie Stephens |
#11 |
I made a video showing how to go down to a 9/16 thread size from the original 5/8's thread.
Its on Youtube. Yes The Model A Ford is also a 40Horse Power Lathe!!! https://youtu.be/lC_zIvb1Yuo?list=PL...5bcpNJQdDfO5H8
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#12 |
briliant you tube tution , thank you.
Have you done many miles since the repair? |
#13 |
2000 miles so far.
#14 |
[QUOTE=Fullraceflathead;1546173]I made a video showing how to go down to a 9/16 thread size from the original 5/8's thread.
Its on Youtube. Yes The Model A Ford is also a 40Horse Power Lathe!!! https://youtu.be/lC_zIvb1Yuo?list=PL...5bcpNJQdDfO5H8[/QUOTE Question: Isn't it hard on the axle seal to run that axle without the hub bearing to center it and keep the load off that seal? Also, since you are using a split die, do you use the set screws in the handle to open the die a little and cut less metal to get better thread engagement with the nut? If the nut can rattle around on the axle threads, you are losing some thread strength, it would seem. |
#15 |
Saw an OLD rear end, the AXLE was ARC WELDED to the HUB!!!
Bill Amazed
#16 |
Once the 5/8 thread is stripped you are not removing very much material per side to get to 9/16".
A sharp file cuts without much pressure. My seal didn't get harmed when I did my axle. A Modern Die is sized to a Modern nut, there is no slop on the fit.
#17 |
Well, To end this thread, we put an electric drill, with a socket in the chuck, and turned the axle from the right side. Friend then held the file to the left axle. Threaded the left axle to 9/16 as in the youtube that Tom Endy presented. This did the job and I think it will be fine but it still seems a little slipshod to me.
Marty |
#18 |
What did he torque the axle nut to when he put the drum back on? Remember if he is running hydraulic brakes to run safety hubs or clips.
Charlie Stephens |
#19 |
He torqued the axle to 100 lbs.
Marty |
