Old 03-03-2013, 11:16 AM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default Can Sheet Aluminum be Spot Welded?
I don't recall seeing spot welded aluminum, but was wondering if it can be done? It would work nice to build a lightweight speedster.
Old 03-03-2013, 11:52 AM   #2
James Rogers
James Rogers's Avatar
Default Re: Can Sheet Aluminum be Spot Welded?
It can just like steel panels but, it would work best for a hobbiest, to use a mig welder and an aluminum gun. You could use a high frequency tig but that is expensive. The aluminum gun is because the wire won't stand being pushed through the housing so you use a gun that attaches to the end of the housing and the wire roll is mounted on it with a small advance motor. Miller carries these.
Old 03-03-2013, 12:48 PM   #3
MikeK
MikeK's Avatar
Aluminum has always had reliability problems with spot welding due to the near instantaneous formation of a thin invisible surface oxide layer that becomes imbedded in the fused weld and provides a shear layer. Simply put, they tend to snap apart in time.
GM recently solved the problem through a patented re-design of the geometry of the electrode tips. I suppose you could get an extra set of tips and try their method. Here's a press-release link from GM that explains what/ how/ why.
LINK Watch the 42 second video for a close up of the tip cutting and resultant welds.
MikeK is offline   Reply With Quote
Old 03-03-2013, 03:26 PM   #4
norson
Lazzi has a video showing how to spot weld aluminum with a regular pinch? spot welder. You sandwich the aluminum with strips of crs and pinch and pull the trigger as normal. the weld seems strong. The problem would be making a whole car this way. I had a Marine Corps Mity-Mite that was made that way and that was a ton of welds. A neat trick when you need it but not a construction choice I would make. Norm
norson is offline   Reply With Quote
Old 03-03-2013, 03:34 PM   #5
hardtimes
hardtimes's Avatar
Hey Mike,
Thanks for that! Hm, using aluminum rivets on a speedster, IMO, adds to the looks/beauty and probably less expensive that welding ?
hardtimes is offline   Reply With Quote
Old 03-03-2013, 03:46 PM   #6
norson
Just saw the video from GM. bet you could make a manual dresser for a pinch? welder to match that welding face. hmmm?
Old 03-03-2013, 04:36 PM   #7
Tom Wesenberg
Originally Posted by hardtimes View Post
Hey Mike,
I agree that rivets add to the looks of an antique speedster.
