09-14-2016, 04:56 AM | #21 |
Re: 35 Instrument Lighting
09-14-2016, 05:15 AM | #22 | |
09-14-2016, 07:56 AM | #23 |
Did you ever take a look at the coil? It would be interesting to see what is being used with the ballast resistor bypassed.
09-15-2016, 06:50 AM | #24 |
09-15-2016, 07:06 AM | #25 |
Measure the resistance of the coil and see what it is. Is it a can style coil or an original attached to the distributor. It is also possible that a ballast resistor has been added somewhere else in the circuit. They are sometimes mounted at the coil.
09-15-2016, 06:18 PM | #26 |
09-15-2016, 07:30 PM | #27 |
My dash light switch is completely different to the one in the pics in my '35 roadster. I've got a uk built car though so will explain the differences.
