Old 10-19-2018, 07:44 PM   #1
37 Coupe
37 Coupe's Avatar
Default Installing engine without transmission or with.
Just looking at what it took to separate engine from transmission bellhousing I just wonder if it would be easier on splines and throw out bearing housing to install engine and then bring bellhousing up to it.Gonna take rear end out anyway,so it would be the last thing to reinstall. Also seems like it would be easier to spread frame if that is going to be necessary for getting engine rear mounts in place,original type not FAM.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 10-20-2018, 06:36 AM   #2
RonC
RonC's Avatar
Default Re: Installing engine without transmission or with.
Easier to separate first due to weight
RonC is offline   Reply With Quote
